I had a similar issue on mine. When I checked in to it I found that the pitch on the motor pulley did not quite match the timing belt. As there were not any numbers on the belt I decided to just get two new pulleys and poly belt that I knew were a pitch match. Another thing I found when I pulled it off was that the large pulley shaft was rubbing on the inside of the clearance slot on the motor adjustment plate, I opened up the slot to ensure that when I tensioned the belt there was no way it could rub any more.
Hope you get it sorted.
"A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
Greetings From Down Under
Dave Drain
Akela Australia Pty. Ltd.
