586,070 active members*
3,430 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 18m (+) Button Enabled Continuously
    Feb 2010
    16
    Exclamation Fanuc 18m (+) Button Enabled Continuously
    My Gantry Mill with Fanuc 18m Controls was working fine yesterday morning. Now it is as if the ( + ) key is enabled and will not disengage. I've hard reset the machine numerous times, and checked to see if the key was stuck. As soon as I press the Jog or Home button, then select an axis the machine begins moving in the ( + ) direction. Is there a way to soft reset the CPU ? Any help would be appreciated. Thanks.
    Feb 2010
    16
    PS. Each axis moves in the ( + ) direction when they are selected. I can move each axis in both directions using MPG.
    Feb 2010
    16
    A little more info: Last week on 10/14 I installed a repaired power supply by Tri Star CNC. the machine was working fine, but looking back in the Alarm History, since the power supply was installed I have an alarm indicating ' 971 - NMI OCCURRED IN SLC '.
  1. Replies: 2
    Last Post: 02-24-2011, 08:22 PM
  2. multicam 3000 tool holder breaking continuously
    By schantal in forum Commercial CNC Wood Routers
    Last Post: 10-19-2008, 05:33 PM
  3. Replies: 4
    Last Post: 07-25-2008, 05:57 PM
  4. Replies: 13
    Last Post: 02-19-2007, 06:09 AM
  5. Fanuc OT control Auto Button
    By thardy in forum Fanuc
    Last Post: 11-12-2006, 04:52 PM
