586,116 active members*
3,469 visitors online*
    Jan 2010
    mazak vtc41 spindle bearing removal
    Hopefully someone can help. We need to replace the spindle bearings on an early 90's vtc 41. We have the spindle cartridge out, pulled the bottom flange off and by the looks of the pictures we have at the top of the spindle there is a threaded collar that needs to be removed to push the bearing shaft out through the bottom. We think it is threaded on but we are not having any luck loosening it. Does anyone have any ideas on this or maybe its not even threaded on. Any help would be appreciated.
    Sep 2008
    93
    I have a procedure for repair spindle VTC.
    your e mail? for send it.
    Nov 2010
    Most mazak spindles i have dismantled are pretty straightforward. the collar that is on the back will unscrew. however the draw tube sticking out the back must be comrpessed in a press to relieve the tension on the cap. be careful letting off on the press, the belleville springs can do some serious damage. make sure you note the position and direction of all springs for reinstallation.
    Apr 2009
    12
    Quote Originally Posted by mantenim View Post
    Can you also give me procedure how to remove bearing in mazak spindle. Thankx email is [email protected]
  1. Okuma Howa VMC spindle bearing removal
    By aryoung19 in forum Okuma
    Last Post: 06-28-2017, 08:27 PM
  2. lathe spindle tapered bearing race removal
    By auburnCNC in forum Uncategorised MetalWorking Machines
    Last Post: 10-28-2012, 02:17 PM
  3. Spindle Bearing Removal
    By RustedOut in forum Charter Oak Automation Support Forum
    Last Post: 07-03-2011, 04:20 PM
  4. Mazak H-400N spindle drive removal
    By Micah in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-18-2010, 09:40 PM
  5. X2 spindle bearing removal
    By skmetal7 in forum Benchtop Machines
    Last Post: 04-14-2007, 07:25 PM
