586,060 active members*
4,328 visitors online*
    Sep 2009
    10
    velocity control unit.
    HI.
    CAN ANY BODY HELPME?
    WE HAVE A CNC MACHINE, IT'S.
    CNC LATHE.
    MORISEIKI TL-5, WITH 6T FANUC CONTROL
    I NEED TO GET THE MANUAL OF THE NEXT EQUIPMENT:
    FUJITSU FANUC.
    TYPE: A06B-6045.
    IT'S A SERVOMOTOR OF THE CNC LATHE.
    WHERE CAN I GET ITS MANUAL?
    I WAS VISITED MANY WEBSITES BUT I DON'T FOUND IT.
    TANKS FOR YOU HELP.
    BEST REGARDS.
    24221
    6T its most likely a DC Servo, (yellow cap)?
    What is the problem? it a DC motor!
    Al.
    Albert E.
    Sep 2009
    10
    THIS IS A OLD CNC MACHINE, AND THE FANUC 6T IS ITS CONTROL.
    THIS MACHINE HAS MANY PROBLEMS.
    THE CONTROL DON'T STAR UP.
    SPINDLE MOTOR DRIVE HAS A PROBLEM (PROBABLY STAR UP PROBLEM CONTROL).
    THE SPINDLE MOTOR TO DRIVE CONNECTIONS ARE INCOMPLETE.
    BUT THE SERVO DRIVES SEEM IN GOOD CONDITIONS.
    I DIDN'T SAW WORK THAT MACHINE BUT I WAS CHECKED AND FOUND THAT.
    I WISH TO ELIMINATE THAT OLD CONTROL AND USE AN SOFTWARE PC AND LINUX BASED (EMC2). BUT I THINK I CAN SOME USABLE INFORMATION IN THE SERVO DRIVE MANUAL FOR THE CONTROL INTERFACE, YOU KNOW..
    Jan 2010
    13
    Al.
    hi i had a machine hitachi seiki 4 NE-2 with fanuc system 6t i had a problem with spindle its rpm are too low a gave him a command to run 3000 rpms but it runs only 300 rpms. plz help me sirrrrrr
  1. Fanuc 5t velocity control unit
    By crazyneosimpson in forum Fanuc
    Last Post: 05-24-2011, 01:27 PM
  2. FANUC 0M Velocity Control Unit
    By gbowne1 in forum Fanuc
    Last Post: 06-23-2009, 06:28 AM
  3. 1.3 amp alarm fuses blow on my Velocity Control Unit
    By gcpmachine101 in forum Mass finishing equipment/media/strategies
    Last Post: 09-26-2008, 03:52 PM
  4. velocity control unit breaker off
    By scr in forum DNC Problems and Solutions
    Last Post: 07-15-2007, 02:18 PM
  5. Replies: 0
    Last Post: 06-07-2007, 04:40 PM
