586,655 active members*
3,051 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > ice sculpture by routing ...
Results 1 to 6 of 6
    Jun 2010
    40
    I want to build some ice sculpture.
    I have the 3D cad file of the sculpture.(back side is flat).
    Can I do CNC routing of the shape in foam/thermocol , pour water into it and let it solidify?
    Will this work? Have anyone tried this method?
    Or should I use some other material to carve the mould?
    regards
    CNCPatriot
    You need to use a material that the ice won't stick to.
    I've seen machines actually route a block of ice, but have never seen anyone make an ice mold.
    Nov 2005
    1468
    You also have to remember that water's one of the few things that actualy expand when it freezes- hence why icebergs/ icecubes float- they're less dense than the water they're floating in cos the frozen water has expanded.
    It's quite a considerable force... probably would crack the mould? unless the mould was fairly flexible?
    I love deadlines- I like the whooshing sound they make as they fly by.
    Jun 2010
    40
    Iam planning to make a open mould, in the sense the top surface of the water will be open and flat. Only the bottom surface will take the shape of the mould.
    And I guess foam will be a good flexible material to accomodate the expansion.
    When I was browsing I also came across people routing the ice itself.
    Wondering why the mould concept is not popular, anyways Iam going to try it out and will post my observations.
    Nov 2006
    303
    Quote Originally Posted by CNCpatriot View Post
    May have something to do with the clarity of the ice. To get clear block they use special freezers that freeze from the bottom up. Allowing the impurities, which cause feathering, to rise to the top. Then that layer is removed with a saw when squaring the blocks. Reveling the crystal clear center. :cheers:
    Iceculture Inc. :: A Different Kind of Ice Company! - Ice Blocks
    Web-site: http://www.innovative-accents.com/
    Blog: http://blue-collar-nobody.blogspot.com/
    Jan 2008
    853
    The company IceCultures has an interesting history. Nasa went to hem to make 'perfect' ice chunks to hit shuttle wing mockups in the wake of the last accident. Turns out this little company is unique in the quality of ice made. << No No No ! No Canadian winter jokes please! >>
    If you are trying the mold idea, try putting a spherical or cylindrical float in the water as it freezes; the expanding ice can push the float up to relieve some of the pressure. They used to put logs in swimming pools to 'winterize' them and help protect the walls.
    Cheers!
  1. CNC for 3D Sculpture
    By st45 in forum Machine Created Art
    Last Post: 04-22-2014, 12:22 PM
  2. Image to Sculpture MASTERCAM X3 ART.
    By n27a in forum Mastercam
    Last Post: 04-04-2010, 08:39 PM
  3. image to sculpture
    By gcioffi in forum Uncategorised CAD Discussion
    Last Post: 07-03-2008, 12:42 AM
  4. Replies: 1
    Last Post: 12-24-2007, 01:45 AM
  5. recomend cad/cam software for sculpture prof
    By bfreedland in forum Uncategorised CAM Discussion
    Last Post: 11-04-2006, 06:16 PM
