586,082 active members*
3,459 visitors online*
    Mar 2010
    tripping the overload
    i fit a 5 inch chuck on my 7x12 and now she trips when started in high gear.
    can someone link me to a schematic so i can bypass the overload circuit.
    Jan 2006
    738
    You don't want to bypass the overload circuit. That circuit is protection for the board. Bypassing it will most likely result in blown components on the controller. Here is a link to a place that does repair on these boards...
    Gerling Laboratories has establi
    As you can see, there are several versions of the controller boards and I don't know which one you have.
    It may be possible to make adjustment to current limit to allow you to run with the 5 inch chuck without damaging the board. You might contact Gerling with your board info and get some help there.
    Steve
    Mar 2010
    Thanks for the reply Steve,
    i found some info last night with the help of this forums bench top machine members and was able to adjust the pots to where she runs the chuck in high gear with 5.5 start up amps and 1.5 amps run.
    i did not check how many amps it takes to stall the motor but it is more then before i messed with the pots.
    She seems to be fine.
  1. Circuit keeps tripping!
    By greasetattoo in forum Benchtop Machines
    Last Post: 06-01-2009, 03:10 PM
  2. fuse tripping on 201 @ ~30 IPM
    By cyclotron in forum Gecko Drives
    Last Post: 05-14-2008, 08:54 PM
  3. Tig welder tripping GFI's
    By Dugg in forum Welding Brazing Soldering Sealing
    Last Post: 01-06-2007, 11:44 PM
  4. Boss keeps tripping out on start up
    By creep_pea in forum Bridgeport / Hardinge Mills
    Last Post: 09-30-2005, 09:12 PM
  5. Mach2 tripping e-stop
    By chas in forum Mach Software (ArtSoft software)
    Last Post: 03-07-2005, 12:42 AM
