586,115 active members*
3,429 visitors online*
    Oct 2010
    37
    dry build or glue from the beginning?
    Did you gentlemen begin gluing from the get go or did you do a dry build first, disassemble, and then glue everything together?
    Im planning on using simple Elmers Wood Glue, if anyone has any other glue suggestions let me know
    Thank You
    My Joes2006 arrived today and has been unpacked and cleaned with the shop vac.:banana:
    Jun 2005
    138
    Dry Build! I don't glue anything until I'm positive that:
    1) Everything is in the correct place
    2) There will NEVER be a reason for me to disassemble that part for a minor modification
    Remember, woodscrews are your friends! After running the screw in the first time, remove it and put a drop or two of SuperGlue (cyanoacrylate) in the threaded part of the hole. Let it cure completely, to harden the MDF, then re-install the screw.
    Oct 2010
    37
    OK, Thanks Dorsal
    Ive done a dry fit of all the pieces last night. This kit is really strong on its own.
  1. Newcastle: Beginning of build plan
    By pippin88 in forum Australia, New Zealand Club House
    Last Post: 09-16-2010, 10:22 AM
  2. do i need to glue it up? when to paint?
    By forgetcolor in forum Commercial CNC Wood Routers
    Last Post: 03-01-2010, 10:50 PM
  3. Beginning to build my Z-axis.
    By zonk2 in forum DIY CNC Router Table Machines
    Last Post: 12-23-2008, 06:17 AM
  4. N at the beginning of each tool?
    By gearsoup in forum Post Processors for MC
    Last Post: 11-20-2007, 03:24 PM
  5. At the very beginning
    By rackbox in forum DIY CNC Router Table Machines
    Last Post: 12-01-2004, 11:56 PM
