587,012 active members*
3,664 visitors online*
Results 1 to 3 of 3
    Apr 2010
    ALARAM 22 MEMORY PARITY ERROR
    DOES ANY ONE KNOW HOW TO CLEAR THE ALARM 22 MEMORY PARITY ERROR MAZATROL CAM T4
    PLEASE HELP ME ANY INFO TO CLEAR THIS ALARM
    Mar 2012
    22 parity error
    I am having the same error on my mazak screen,
    did you find a way to clear out this error since you had it in april/2010
    thanks
    Reset 22 error
    Quote Originally Posted by assadmuhannad View Post
    thanks
    I have tried this procedure for T2 M2 controls, but if you have FX701 PCB then it should work the same
    1) Turn off machine.
    2)On FX701 PCB change you will be able to see an 8 position DIP switch on top of the board without having to remove the board. (the dip sw may have a clear plastic cover, remove it) Change the second sw from top to bottom.
    3)Turn machine ON and leave it on for a few minutes (3 or 4 should be fine)
    4)Turn machine off and change sw to its original position
    Hope it helps
    By the way, I have a T4 lathe without any manuals, could you send a copy if you have them? operation and programming?
    jolulank
  1. FANUC PARITY ERROR
    By DIE FAST in forum Fanuc
    Last Post: 03-28-2022, 01:33 PM
  2. 10T Ram Parity Error
    By grease in forum Fanuc
    Last Post: 01-23-2011, 12:22 PM
  3. 001 TH PARITY ERROR
    By jlviloria in forum Fanuc
    Last Post: 10-08-2009, 01:26 PM
  4. Ram Parity Error
    By rags in forum Fanuc
    Last Post: 12-19-2008, 09:03 PM
  5. How to erase ALL T2 OP parameter and 22 NMI Memory Parity problem?
    By Donatello Tam in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-14-2007, 06:01 PM
