586,119 active members*
3,493 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > A replacement for servomac DC Drive
Results 1 to 10 of 10
    Aug 2008
    15
    Please I need a dc drive that will replace a CNC Lathe machine z axis DC Drive PART NO (3ANO1450) PART DESCRIPTION (MAT 1450 DRIVE)
    The make is Servomac & the DC Motor spec is
    Power 6.8kw
    Current 22amps
    Tacho 7mv/min
    Any help will be welcomed.
    Dec 2003
    24221
    If it is analogue control and encoder feedback to the controller, look at Advanced Motion Controls 100A40/100A40AC.
    Al.
    Albert E.
    Sep 2010
    1765
    Al, just curious: why not an amc 100A25 instead to save money?
    Dec 2003
    24221
    The 100A40 is the only one that is still active or current item.
    The B100A40 will also work just as well, I suspect the difference in price between the 25 & 40 is minimal, also I did not know for sure what the operating voltage was for the Servomac?
    Al.
    Albert E.
    Aug 2008
    15
    Al.
    The suply voltage is 110vac three phase
    Sep 2010
    1765
    the 100a40AC model accepts 110vac input. check it out at a-m-c.comn or on ebay or ask Al_the_man -maybe he sells them??
    Aug 2008
    15
    Quote Originally Posted by mike_Kilroy View Post
    Thanks Mike
    I could not find 100a40AC at -m-c, Al_the_man any further help?
    Dec 2003
    24221
    I guess they do not carry them any more? Just the 100A40 which requires a DC supply.
    The B100A40AC works just as well with DC brushed motors.
    http://www.a-m-c.com/download/datasheet/b100a40ac.pdf
    Set the commutation to 60° and use the U V outputs.
    Al.
    Albert E.
    Sep 2010
    1765
    Remember too you can buy the dc input one and also buy a small ac->dc power supply from them to run it....
    Aug 2008
    15
    Thanks I will place my order next week.
  1. Shoptask lath drive train replacement
    By kb7vms in forum Shopmaster/Shoptask
    Last Post: 09-21-2022, 02:49 PM
  2. A replacement for Servomac DC Drive
    By baba1511 in forum Servo Drives
    Last Post: 10-23-2010, 02:16 AM
  3. Ah-ha 64SD drive replacement
    By famoldin in forum Stepper Motors / Drives
    Last Post: 10-31-2009, 11:34 PM
  4. spindle drive replacement
    By duckslayer in forum Haas Mills
    Last Post: 08-13-2007, 01:31 PM
  5. Brushed servo drive replacement
    By motordude in forum CNC Machine Related Electronics
    Last Post: 07-06-2004, 07:09 PM
