586,946 active members*
2,699 visitors online*
    Oct 2010
    CNC Plasma torch?
    I am designing a CNC Plasma cutter but do not feel like spending over $1k on a machine held torch. Any cheaper alternatives? Any suggestions on how to support and trigger a hand held torch?
    Nov 2008
    22
    Cheap solution:
    More cheap:
    Oct 2010
    Thanks for the pictures thats what I am looking for
    Jul 2005
    2415
    If you are going to fire the torch from the PC/control all it takes is a simple relay and a couple of Scotchlok wire taps. You just put the relay contacts in parallel with the switch wires that come from the hand torch. Locating the switch wires is pretty easy and with the ScotchLoc you don't have to cut or splice wires. Then either switch will activate the torch. All the switch does on the hand torch is short across to logic level inputs on the plasma internal control boards. Any good THC solution will have the relay built into the interface card and have instructions on how to connect to most plasma units including hand torch models.
    TOM caudle
    www.CandCNC.com
  1. Plasma Torch Crashing
    By aaronbee in forum G-Code Programing
    Last Post: 12-05-2009, 02:02 AM
  2. Plasma Torch
    By Dembo in forum Waterjet General Topics
    Last Post: 09-26-2008, 07:27 PM
  3. Plasma Torch questions
    By Thundercnc in forum Waterjet General Topics
    Last Post: 04-03-2008, 06:03 PM
  4. blower for plasma/torch cfm??
    By DanOSB in forum Waterjet General Topics
    Last Post: 01-10-2006, 02:55 PM
  5. plasma torch triggering
    By anthony in forum SheetCam
    Last Post: 05-05-2005, 07:03 PM
