Originally Posted by
angelw
That error message would indicate that G74 on your machine is not a tapping cycle but more likely an End Face Peck Drilling Cycle. It would appear that G74 for tapping is a machining center dedicated command, the same as G90 on a mill is absolute and on a lathe a canned cycle.
G88 is the side rigid tapping cycle, but I see in one of your previous post that you tried that with M04 and got CCW in and out.
You could try setting bit 2 of parameter of 5205. With this bit set the rotation of the tool returning from the bottom of the hole will be CW, but there is a warning that if rigid tapping is to be used then this bit should not be set, as damage to the tap, work piece, or machine may result. However, I believe that this warning is given on the basis that a CW rotation on the way in was expected. Try this parameter change with the G88 cycle, as this cycle is definitely designed fro side tapping, and use M04 as you had before. If this works, I'm fairly sure that a User Macro could be written to change this parameter on the fly. Accordingly, store this and call it with a user defined M code any time you need to use it. Probably getting ahead of ourselves with that last comment; see if the G88 with parameter change works first.
Regards,
Bill
