586,089 active members*
3,757 visitors online*
IndustryArena Forum > CAM Software > Vectric > any one involved in marquetry work
Results 1 to 9 of 9
    Jan 2007
    91
    i am new in this marquetry work. i hav a laser cutting machine, which i would use 4 cutting veneer but i have too much issues while cutting veneer paper using laser, so any body involved in such type of work please get me some information
    any help would be apprecieatable.
    Dec 2010
    If you can get a hand operated fret saw such as:
    File:Fretsaw.jpg - Wikipedia, the free encyclopedia
    And hold it at a 13* degree angle-either right or left and stack your veneer on top of each other to cut through the whole stack at once-as in your background piece and another -they will fit perfectly inside one another and leave a crisp edge. It takes a little practice but you will get the hang of it pretty fast. It is fun to do and can become quite elaborate in detail.
    Have fun!
    Oct 2010
    What are the problems with using the laser?
    Jan 2007
    91
    When i work with laser machine , i find difficulties
    how can i cut veneer paper for complicated designs, when it starts cutting the veneer seems to bending,even if i cut how can i remove all the design cut veneer to sticking in other laminates,i dont know the procedure , leading to damage of the veneer
    Please give valuable ideas
    Jan 2007
    11
    Have you thought of making a sandwich? Solid wood, plywood or fiber board above and below the laminate and then cut it?
    Jun 2014
    777
    Re: any one involved in marquetry work
    Drag knife?
    Jan 2007
    11
    Quote Originally Posted by loyedp View Post
    Sounds like the veneer is being affected by the heat from the laser.
    You could test your duration of the laser exposure, treat it more like a router taking small cuts rather than a laser scroll saw. Give it time to cool off before coming back to it.
    Mar 2013
    Sorry i have no idea about marquetry work so i can't help you but i am found this website in Google and hope this will be helpful for you.
    skynet.ie/marquetry/?page_id=65 . here you can find some guidelines about marquetry work.
    Aug 2015
    16
    Please view this Instructable:
    Laser Marquetry & Inlays - My Techniques
  1. need help(marquetry works)
    By loyedp in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-03-2015, 10:26 PM
  2. other factor involved?
    By Claude Boudreau in forum Linear and Rotary Motion
    Last Post: 11-15-2012, 01:26 AM
  3. What steps and parts are involved wiith a SX2 CNC conversion?
    By J S Machine in forum Benchtop Machines
    Last Post: 08-29-2011, 01:10 AM
  4. rail selection (forces involved in cutting)
    By daedalus in forum Linear and Rotary Motion
    Last Post: 11-17-2005, 04:30 PM
