Hi jdr,
From our knowledge this cannot be changed due to code within the machine software, its is pre programmed to return to reference once the program is complete. If running in automatic, this is vital as the exchange table can't change until the machine is signalled to return to reference. It maybe possible to program with many repeats in the one program however you wouldn't be able to utilise edge detection and you would need to shift origin at the start of each new channel (probably more complicated and time consuming). Hope this helps.
MBA Engineering. www.mba-eng.co.uk
Visit our online knowledge base for solutions to your Bystronic problems.
