586,882 active members*
3,915 visitors online*
Thread: Relay Board
    Oct 2004
    198
    Relay Board
    Hi Guys,
    Does anyone know if you can get a opto-isolated relay board that accepts 10-32v input (to suit our old proximity sensors) and outputs the required 5v to communicate with pc?
    Darc
    24223
    Grayhill, Potter & Brumfield, Opto22 all sell different configuration of I/O boards that any of their plug in opto devices will work with, most of the I/O boards will work with other companies modules.
    They come in 4,8,16,32 module positions.
    I believe the module you would want to use is Opto22 G40D24.
    Al.
    Albert E.
    Jul 2003
    1754
    as Al said - Grayhill, Potter & Brumfield, Opto22 all make these. I think I am currently using all those brands in my project. they all seem to work great. The only thing to complain about would be the opto22 modules don't have a very bright led. (thought something wasn't turning on - figured out I needed to look strait into the led to see that it was on.) That is using 5 volt logic.
    sam
    Oct 2004
    198
    Thanks guys, I'll check it out.
  1. Relay for HobbyCNC board
    By pilotjunky in forum Hobbycnc (Products)
    Last Post: 12-24-2008, 07:50 PM
  2. Correct Relay board for Mach and router
    By WilliamD in forum Mach Software (ArtSoft software)
    Last Post: 04-17-2008, 12:54 AM
  3. CNC4pc Solid State Relay Board.
    By Smackre in forum CNC Machine Related Electronics
    Last Post: 05-21-2006, 09:19 PM
  4. cnc4pc relay board question
    By Stuff-Builder in forum CNC Machine Related Electronics
    Last Post: 03-17-2006, 04:17 PM
  5. Mach2 & Rutex relay board.
    By ynneb in forum Mach Software (ArtSoft software)
    Last Post: 08-22-2004, 07:50 PM
