586,459 active members*
3,367 visitors online*
Page 1 of 2 12
Results 1 to 20 of 36
    Apr 2009
    290
    CNC router for University College
    A year and a half ago I built this router. This was something I, by chance, put on my CV when applying for a workshop technician/advisor position at a University College, Department for Product Design. By strange coincidence this was exactly the kind of person they were looking for as they had, for some time, wanted to expand their workshop capabilities with automation/CNC. In other words, I got the job
    As this is a fairly small department, we did not want to go overboard with the machines we purchase/build in this first stage. So this is what I have done so far:
    I have just ordered a Sieg KX3S cnc mill for our metal workshop.
    My challenge here was that the only machine the Norwegian distributor had in stock was the one prepared for Sieg’s proprietary control software, and thusly has a network port connector. I want to run MACH3 as this is what I use at home and what I intend to use on the router I am about to build.
    I am fairly certain that the Sieg prepared machine and the MACH3 prepared machine both utilize the same breakout board internally and that it will be a fairly simple re-wiring job. I have emailed Sieg directly and hopefully they’ll be able to advise me
    Now on to the main reason for this thread: The router build
    My design is probably 75% done. I will document my design and my choice of hardware in the following posts.
    My previous build was fairly lo-tech so I would immensely appreciate any and all feedback and opinions from you guys, so I can end up with an efficient and sturdy router for my students.
    Mikael
    "Hey! It's that guy you are!" - Phillip J. Fry
    Apr 2009
    290
    The main building material will be aluminum t-slot profiles from Rollco.
    As they currently don’t have CAD files for their profiles I’m just using generic boxes with the correct dimensions in my design. I have color-coded them to differentiate the sizes
    BLUE - 80x160mm
    GREEN - 80x80mm
    ORANGE – 40x40mm
    BROWN – 28x160mm
    The dimensions of the room that both the cnc machines will be in, as well as our needs obviously, dictated the size I chose for the table: 1400x2200mm
    Having not worked with aluminum profiles before I am questioning if I might have gone a little overboard on the largest profiles. The 80x160 also comes in a “light” version, and I am wondering if they might do. Any opinions?
    I’m having a meeting with a salesman from Rollco on Tuesday and hopefully he will be able to advise me a little too.
    All the linear guides and ballscrews will also be from Rollco
    In my preliminary design I have opted for Rollco’s Belt Driven Linear Unit for the X axis [nomedia="http://www.youtube.com/watch?v=F_vhc5LR3y0"]YouTube - Assembly of a belt driven linear unit RHL80 from Rollco[/nomedia].
    It will have a timing belt driven gear reduction from stepper motor. It appears to me to be an ideal choice in regards to it being an enclosed unit, but I am unsure of it’s precision and rigidity. Anyone have any experience with this type of unit?
    If it turns out the belt unit is unsuitable I am leaning towards rack & pinion for the x-axis. More work in regards to fabrication, but a tried and true system.
    The y-axis is, as stated, 1400mm and here I am opting for a 20mm ballscrew with either a 5 or 10mm pitch. Possibly gearing the stepper up slightly with timing belts for higher rapid speeds.
    My goal, in regards to speed, for the router is at least 10m/min rapids for the x-axis and slightly lower for the y-axis. I don’t think this is unrealistic. Any views?
    Please disregard all the errors with the placement of the trucks for the linear guides… I’m working on it
    Mikael
    Apr 2009
    290
    My purchase list of electronics is also taking shape.
    Apart from the C11 multifunction board from CNC4PC, I intend to purchase all the components, that aren’t readily available here in Norway, from DamenCNC in the Netherlands.
    This list, so far, contains the following:
    Teknomotor C41/47-C-DB-P, 2kW spindle ER25 collets
    Delta Electronics 2.2kW VFD
    PoKeys55T
    PoPendant
    2pc. 48V 6A switching power supply
    4pc. HP5056, 5.6A 50V stepper driver
    4pc. DCNC-IP54-4,5NM NEMA 34 stepper motors
    Mikael
    Apr 2009
    290
    A tiny digression. This is a quick walk-through of the workshops where I get to play... I mean work every day
    [nomedia="http://www.youtube.com/watch?v=-XB-7lHAT8c"]YouTube - HiAk Workshops walk-through[/nomedia]
    Mikael
    Aug 2004
    54
    with all that fine woodworking machinery at your command ,you might want to take a look at this german site. Schreinerei stefan Welschoff CNC-Wood - Home they show a large and a small machine made largely of wood .google will translate the german to english .
    sincerely ,
    eigstein
    Aug 2004
    54
    this is a add on to the page we just posted . CNC-Wood - Home is what we typed . but cnc-wood-home is what we got ? you can get there from that adress but it is not direct.
    eigstein
    Aug 2004
    54
    i've just exposed my ignorance of e-mailing.
    eigstein
    Apr 2009
    290
    Thanks for the link, it worked fine
    I considered a wood based construction like my first router build, but decided on aluminum for a couple of reasons. The machine needs to be robust enough to withstand use, and certainly abuse by the students. And, I want to be able to dismantel it into manageable bits so we can, for example, take it to education expos as a promotional gimmick. My experience with wooden constructions like my last build has taught me to keep dismantlig and re-assembly to a minimum.
    Mikael
    Mar 2008
    52
    Du kan jo vurdere ac servo kit fra dmmtech.com
    Utrolig fine komponenter og god service
    Apr 2009
    290
    Quote Originally Posted by slektning View Post
    That was indeed a great price, but I think servos will be slightly overkill for this build
    Mikael
    the url is www.dmm-tech.com btw
    Apr 2009
    290
    I've had some email correspondence with Kevin from http://www.damencnc.com today, and his service has been outstanding. He will be advising me a bit on my choices of hardware in this thread so hopefully it will be of help to others as well.
    Mikael
    Apr 2009
    290
    I have tried to calculate how much the router will end up weighing based on the profiles, linear guides and ballscrews I will be using. I’ve just “guesstimated” the weight of the remaining components. I've come up with the following values.
    Table with legs: approx. 280kg
    Gantry complete: approx. 45kg
    I also had a meeting with the sales rep. from Rollco today which was very enlightening. We went through all my requirements to build the router according to my current design and I was given a very good deal. Still, my initial cost estimate has turned out to be off….. quite a bit off actually so I will need to present the new budget for approval before I move any further. Shouldn’t take long though.
    Wish me luck
    After a guarantee from Rollco that the belt units will meet my precision/repeatability requirements, I’ve decided to go for this option for the X axis.
    For the Z axis we decided on a complete bolt-on unit with a 300mm stroke. (see picture)
    For the aluminum profiles I decided to go for the “light” versions of the 80x160 and the 80x80. He had some samples of both versions, and I am positive the “light” versions are more than rigid enough. It will save me about 45-55kg on the entire build, and the cost was considerably less.
    Mikael
    Apr 2009
    290
    I need a little feedback on the following:
    the Rollco RHL80 belt unit has a stroke of 180mm/rev
    the NEMA 34 stepper has a 14mm shaft which will allow minimum of a 20 tooth pulley
    The T5 series pulleys for 25mm belts seem to have an upper limit of 60 tooth pulleys
    this will give me gear reduction of 1:3
    that will reduce the stroke to 60mm/rev of the stepper
    60mm divided by 200 steps/rev gives me a resolution of 0,3mm/step..... this is not good.
    Am I getting this all wrong? or do I really need a gearing closer to 8:1 or something like that?
    Mikael
    Apr 2009
    290
    Well, some feedback would be nice, but I think I found the solution in this product from DamenCNC. V40 i 1:10 WormGearbox Reduced Backlash.
    The cost keeps escalating rapidly, so I need to go through the entire build again and prioritize.
    Mikael
    Feb 2006
    174
    Congratulations on the job! I want one like that.
    I think you are complicating things with the belt drive units. Dual screws with 10mm pitch and direct drive would propably be stiffer, simpler and cheaper to build.
    Lars
    Apr 2009
    290
    Quote Originally Posted by LN-JET View Post
    Lars
    Thank you Lars I really do love my job!
    While the belt units, indeed, are pretty expensive, the alternative with linear guides, blocks, ballscrews, nut, mounts etc etc won't end up being that much cheaper. Another factor is that even a 10mm pitch ballscrew with direct drive won't give me the rapids that I am looking for. The belt drive with the 1:10 gearbox should easily give me 14-15,000mm/min. Not that I am aiming for speed for speeds sake, but usable speed will give me an efficient machine when I have a line of students at the door waiting to have their parts cut
    Mikael
    Apr 2009
    290
    Everything is now ordered for the build.... the waiting game begins
    The Sieg SX3S should be arriving any day now, and will be set to work making parts for the router build.
    I've got two students to assist me with the build, and hopefully they will contribute to this thread as well.
    Mikael
    Sep 2007
    99
    Jeg holder på med en tillsvarende maskin i aluprofiler, jeg kjøpte mine profiler fra AluFlex Group de har også cad profile du kan laste ned.
    Steppmotorer fikk jeg fra Kelling
    Her er en liten link til prosjektet mitt
    Min benk vil veie ca 100Kg i følge Solidworks men så er den ikke så stor som din, ca 700x1300.
    Runar Holm, Norway
    www.maxmekker.com
    Apr 2009
    290
    Hi Runar!
    That's a great looking router. When I get around to building a new router for my home workshop, I'm going for something like that.
    Were AluFlex allright to deal with for privat purchases?
    Do you have a plan for when you will have it running?
    Mikael
    (jeg tenkte det var greit å holde seg til engelsk i denne tråden siden den ligger i den internasjonale delen. Hvis du heller vil diskutere på norsk så har jeg en tråd i det norske forumet her: http://www.cnczone.com/forums/norweg...nytt_bygg.html )
    Sep 2007
    99
    Hi.
    Thanks for the good words :-)
    I have a hope that I can get it up and running around X-mas.
    Today I'm going to put the screws in to my lathe and get at least two of them finnished and mounted.
    I'm strugeling with time to fiddel with it :-/
    If Aluflex is dealing with private purchase that I don't know, I bougt it tru my work.
    Linear bearing I bought from a guy at MFN.
    In the bottom of my building blog there is a google translate bar if any body need to translate from Norwegian.
    I see now that I answered in the wrong thread, sorry for that.
    Runar Holm, Norway
    www.maxmekker.com
Page 1 of 2 12
  1. Mastercam University
    By littlebrewman in forum Mastercam
    Last Post: 06-04-2017, 06:41 PM
  2. Machining as college job
    By Nitro Turkey in forum Community Club House
    Last Post: 08-20-2009, 05:29 PM
  3. WARDJet Partners with the University of Sheffield AMRC with Boeing
    By WARDJet-Ken in forum News Announcements
    Last Post: 03-24-2009, 09:17 PM
  4. VMC & tooling for a university physics shop?
    By phyzzle in forum Uncategorised MetalWorking Machines
    Last Post: 09-17-2007, 05:33 PM
  5. University Digital Electronics Class Project.
    By wholepair in forum Stepper Motors / Drives
    Last Post: 04-27-2005, 05:49 AM
