587,072 active members*
2,843 visitors online*
    Mar 2006
    14
    New to bobcam
    I am currently using the demo, waiting for the actual software to arrive. When I merge in a solid weather it be a sat., step., or stl., I am unable to select holes or seperate entites within the solid. The whole thing ends up selecting. It doesnt seem to matter what I have the selection mask set to.
    if you save your cad file as an iges file then you'll be able to select various features on the part
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Mar 2005
    368
    Quote Originally Posted by westerfieldcct View Post
    ...I am unable to select holes or seperate entites within the solid. The whole thing ends up selecting....
    Use Utilities > Extract Edges > From Entire Solid to extract selectable entities.
    (don't ask why....it is what it is)
    Also, helps to first define a new layer on which to extract these edges. You can then hide the layer containing the solid, thus making edge selection easier.
    Dec 2008
    4548
    For 2d toolpaths, you will extract edges.. For 3d toolpaths, when you go to select geometry for the feature, the individual surfaces will be selectable... If you dont want a solid defined, you can "Unstitch solid to surfaces"..This is what bringing in an iges file without selecting the "make one solid" option is..Just bringing in all the surfaces un-joined.
    An STL will be just a dumb solid.. You cant unstitch it or select anything other than the entire object (Make good use of boundries with this)..You also cant perform any other ops with an stl, like booleans or getting edges.
    Mar 2006
    14
    Thanks for the help.
  1. BobCam question
    By cncadmin in forum BobCad-Cam
    Last Post: 07-13-2010, 09:09 PM
  2. BobCAM for SolidWorks
    By CNCdude in forum BobCad-Cam
    Last Post: 05-31-2010, 02:04 PM
  3. BobCAM
    By CNC_Nick in forum Community Club House
    Last Post: 12-22-2009, 07:52 PM
  4. Anyone using BobCAM?
    By kevperro in forum Tormach Personal CNC Mill
    Last Post: 08-24-2009, 05:52 AM
  5. bobcam v12.5.2
    By vividdezigns in forum BobCad-Cam
    Last Post: 08-19-2008, 07:48 PM
