586,052 active members*
3,935 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Development Question
Results 1 to 3 of 3
    I recently had to do a job for a customer which consisted of 68 'Fan Blades' radially mounted (See Pictures)
    The actual fan blade was made from 3mm Stainless Steel and incrementally folded on a Press Brake.
    I am still learning Solidworks and I didn't have the required knowledge to do it
    So I had to use the old fashioned way using triangulation and development (A dying art now!)
    I am sure it must be quite easy to do in Solidworks, any ideas?
    Andy
    Attached Thumbnails Attached Thumbnails Development.JPG   Development2.JPG   Development3.JPG
    Aug 2010
    90
    walk thru
    send me the blade specs and I'll do a walk thru :wave: [email protected] :rainfro::rainfro:
    Apr 2010
    Hi.
    try to do it this way:
    1: model the two rings as solids
    2: make a lofted surface between the two rings with the profile of the fan balde
    3: thinken it to 3mm - make sure to uncheck ''merge result'' (so you will have 3 solid bodies)
    4: make a cirkular pattern with the fan blade body selected in ''bodies''
    5: combine it to one solid.
  1. Looking for Input for Development
    By charger19690 in forum Mentors & Apprentice Locator
    Last Post: 02-28-2009, 07:02 PM
  2. Low cost table CNC development
    By dfreiberger in forum News Announcements
    Last Post: 02-24-2009, 08:07 PM
  3. Development of TurboCNC?
    By norby in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-19-2007, 02:24 AM
  4. after the development
    By Equinox in forum Community Club House
    Last Post: 12-01-2005, 07:02 AM
  5. Electronics development going well
    By owhite in forum CNC Machine Related Electronics
    Last Post: 03-25-2004, 11:06 PM
