586,116 active members*
3,439 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > x axis will only move 1 direction
    Jan 2009
    25
    I have recently bought a xylotex board and stepper motors etc. i installed all of these units and installed mach3 on my computer. configured the motors etc. all was working well. when i started the computer up the other day and tried to jog all the x,y, z\and z axis the x axis would only move in the + direction. The counter in mach 3 showed that when i used the x++ button the digits moved in the + direction. when I pushed the x- button the counter moved in the - direction. however, my router was still moving in the x++ direction. I treid reinstalling mach3 in case i had messed around with stuff i shouldn't have but still have the problem. I really don't know what i'm doing so rather than keep blindly bungling on, i thought i would toss it up to the brains trust that is in this forum.
    can anyone help me??
    Not sure if this is the right forum to post this as i don't know if it is a software issue or a motor issue
    Brent
    May 2005
    1397
    I just had this problem yesterday in TurboCNC... For me, it was that I had the parallel port configured incorrectly. The new BOB for the Linistepper drivers that I was working on uses a slightly different pinout than then old one, so it used to be that pin 3 was the direction for the x axis, and now it is pin 6. The program was still set to put the direction signal on pin 3. Once I told TurboCNC to put the direction signal on the right pin, it worked correctly.
  1. KM3P will not move in Y- direction
    By BrianP in forum HURCO
    Last Post: 09-12-2010, 08:01 PM
  2. Y axis cannot move up...
    By rararuru in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-30-2009, 02:21 AM
  3. All axis will not move
    By SELECT in forum Fadal
    Last Post: 09-30-2009, 04:37 PM
  4. cog belts that move when spindle changes direction
    By FanucIssues in forum MetalWork Discussion
    Last Post: 07-26-2009, 08:42 AM
  5. x axis will only move one direction
    By CATCH22 in forum Mach Mill
    Last Post: 12-17-2007, 03:53 AM
