Okay! Revision 1 of my design is ready!
The first photo is an overall view of the machine. The Axis movement dimensions are 111" x 28.75" x 8.5". So with safety margins, that gives me a cutting area of 109.5" x 27.25" x 7.75"! The machine's operating external dimensions (room for the motors to move etc.) are 120" x 50" x 22"
The table needed to fit in a very small room in my Dad's basement. The room used to be where the coal was stored to heat the house, and it has since been converted into a sudo-workroom / storage area. The room dimensions are 13' x 7.25' with a 6' ceiling. The machine (I will now refer to it as Rex2... just keeping with a theme even if I didn't stay with that girlfriend) is actually a little larger than I originally mapped out the space for, but I think that I can live with that. If not, altering the Y axis dimension is as simple as undoing a bunch of bolts and sliding the two X rails closer to each other.
Rex2 uses 1530, 3030, and 3060 profiles in it's construction. I would have used more 3060 if it weren't so darn expensive! With this design there is a total of 12" of it, which amounts to about 15$ on eBay... I think that I can handle that.
The X axis rails are 3030 with 4" x 1/4" CRS. All of the cross pieces in the table are 1530 extrusion cut to 39.75". This way I can get 3 of them out of a 120" rail (Which is the length that I would be ordering because of my two X rails). There are 9 stringers total, which means that I will use 3 120" 1530 extrusions in the table.
The second and third photos depict the clearances available in the gantry. I cantilevered the 3030 crosspiece on the 3060 supports and if gave me another ~7" of usable travel in the Y direction. This cantilever reduces the rigidity of the machine, but I don't think that it will be by much. To stiffen the gantry further, and fill the void left by the 3030, I added a piece of 1530 and a bunch of various types of gussets and joining fixtures.
One day I would like to create some sort of 'H' connector that would be used to fix two extrusions that are parallel to each other together. It would slide inside of two adjacent slots and would be able to be tightened through and access hole drilled in the extrusion. Maybe something like exists, but I haven't found it yet.
Finally, the last photo simply shows how the Z rail can now touch the X-rail; which is the most possible travel out of a machine of this design base.
Any input would be very much appreciated. This is my first real attempt at designing a large scale CNC machine of some sort. By no means is this design set in stone, so please feel free to suggest any improvements that I could make to it. The success of Rex2 is depending on your input!
"The bitterness of poor quality remains long after the sweetness of low price is forgotten"
