586,058 active members*
3,425 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Citizen Start Position L520....L720
Results 1 to 6 of 6
    Mar 2009
    76
    When going to start position from start position ; Does anybody know what causes the cutoff tool to jump up to position point then back to start position.
    304
    The "X" position at the end of your program is NOT the same as the position stated in your "MC DATA" or you did not cancel the offset when it went there.
    G50Z.625
    M7
    G0X#824Z.625T0
    M6
    Mar 2009
    76
    That was my initial thought as well. If I use preparation to move the machine to start position and wait till the cycle is complete, then repeat the cycle, the X axis rapids up to position point then back to start position??
    May 2010
    I have had the same thing happen to me and it was because I didn't run the cutoff cycle first. You need to run the cutoff cycle then run the start position.
    Jun 2011
    Quote Originally Posted by chet470 View Post
    I think that is just part of the process, similar things happen like when setting a tool length on $2. You jog $2 using the cycle start button, to "Adjust" postion, you then set the tool. Then I often select the cycle again, $2 jogs back using the cycle start button, like before. if you continue to jog $2 in will come back into the "Adjust" again, but I just hit reset once its back out of the way.
    I find this method quicker than using the wait cycle, then/or handle to move back out of the way, plus has the added bonus that you ain't gonna move the wrong way. The machine will do this for all tool sets etc
    Machine is K12
    304
    The position at the end of your cutoff cycle (X-.120 or something like that) needs to be the same as what you put into your MC DATA "Cutoff End Position" (#824) Also after that is done you open the collet (M7) and RAPID back to start position (G0X-.12Z.586T0), Make sure that "X" is the same as your MC DATA and that you have the "T0" or it will make the cutoff go up and back down.
    I promise, if those are the same, it will NOT do what you are saying.
    If they are NOT the same it will do it eveytime you do start position after a cycle.
    Been there, done that!
  1. Citizen A32 Z70-0001 Zero position error
    By smellyfeet in forum CNC Swiss Screw Machines
    Last Post: 06-15-2010, 01:20 PM
  2. Controlling the Pocket Start Position
    By Ed from NY in forum BobCad-Cam
    Last Post: 08-29-2009, 06:35 PM
  3. citizen f16 no start
    By wdzhere in forum Fanuc
    Last Post: 05-28-2009, 09:43 PM
  4. Tool Start position
    By Mike.C in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-17-2008, 03:20 PM
  5. Cut start position in 2d cutting?
    By DennisCNC in forum Visual Mill
    Last Post: 04-04-2008, 04:33 AM
