Last night I had some problems with our TM-2.
I probed the Z axis and got a value of 11.500 . Then I manually went in and moved the G54 offset in the offset screen for X & Y (moved them 2.0" each way).
Then I moved the probe to the new z zero point. The G54 was still indicating the original offset but the offset in the offset window had the correct numbers in it.
So I decided to test the code I had. Set the Z up 3" and let it run. The offset for the x&y was incorrect and the Z was off also.
After this I re-probed the Z and got a value of 18.xxx. I then probed a corner of a 123 block and got the x&y offsets to update.
I'm calling haas after lunch about this. Could be a serious issue if I had not double checked everything.
Tim
