586,103 active members*
3,215 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Coolant pump manifold question
    Apr 2005
    903
    2008 VF2
    Is this correct?
    A. Coolant from pump
    B. Coolant to spindle
    C. Over flow return from spindle
    What is D and E for? They are connected together with an on/off valve into the supply cavity of the manifold. (???)
    D.
    E.
    Oct 2009
    192
    Here is what you need to do to pipe up the coolant correctly.
    Leave A with plug in.
    Unplug hose from E and connect the hose to the coolant pump.
    You should have a wash down kit that plugs into E instead. (the wash down kit is a length of hose approx twelve feet long with a spray nozzle on the end)
    B and C - (are piped correctly) one is hose to spindle head - the other is a wash down function inside the machine at the bottom of the Z axis waycovers.
    Hope this helps
    Apr 2005
    903
    Ahh, thanks.
    I do have a length of hose but I didnt get the spray nozzle. Is that something I can get at a hardware store?
    Question, should the pump have a basket it sits in inside the tank?
    Oct 2009
    192
    You should be able to get a nozzle froma hardware store no problem.
    There is not normally a basket filter for the pump. There is on the lathes but not on a VF2. There is a basket on the new machines that fits under the coolant return to filter out swarf from returning coolant - but not a basket for the pump to fit in.
    Hope this helps
    Apr 2005
    903
    thanks
  1. Tm Coolant Pump
    By behindpropeller in forum Haas Mills
    Last Post: 03-15-2010, 04:45 PM
  2. New coolant manifold
    By zephyr9900 in forum Tormach Personal CNC Mill
    Last Post: 12-01-2009, 09:55 PM
  3. Coolant Pump Question
    By jamiedaugherty in forum Uncategorised MetalWorking Machines
    Last Post: 01-27-2009, 01:57 PM
  4. coolant pump
    By JACKSMACHINE in forum Fadal
    Last Post: 05-22-2008, 09:13 PM
  5. Haas VF2 Coolant Pump (Pressure) Question ...
    By Mike Braddock in forum Haas Mills
    Last Post: 06-09-2006, 01:54 PM
