586,123 active members*
3,231 visitors online*
    Oct 2010
    83
    Defective Router bit
    I was recommending the Woodline Router Bits. But I think they must have changed hands and moved from Payson, AZ. I ordered a 90 Deg V bit from them. The bit would not cut a sharp V in the bottom of the cut on my CNC. Looked at the bit with a strong magnifying glass and could see that the carbide cutters did not come to a point. They said that they would refund my $ if I would return the defective bit. The bit was only $16.20 but the shipping was $7.72 ground UPS. They refunded the $16.20 but not the shipping. So I'm out the $7.72. Only saved $8.48, by sending the bit back. I would have been better off to put the bit in the trash. It would have been different if I was returning a bit that was not defective. Could have saved a trip to the UPS office and $6.00 in gas. Not counting boxing the thing up.(flame2)
    Jun 2010
    463
    Defective Router Bit
    Have you considered using insert cutters, the cost is a little more initially but after that 1st order then all you are doing is replacing the inserts and nothing more.
    Vortex Tool: Solid Carbide Router Bits and Compression Spirals for woodworking, plastics and non-ferrous industries.
    Oct 2010
    83
    Yes I have. I replaced the Woodline with a Amana RC-1102 90 Deg bit. Like you say they cost more, but next time I only need a replacement knives.
  1. Defective Geckodrive
    By Wood Chuck 59 in forum Gecko Drives
    Last Post: 10-22-2009, 03:29 AM
  2. Defective transformer?
    By sotx in forum CNC Machine Related Electronics
    Last Post: 04-09-2009, 05:50 AM
  3. New Compressor defective ?
    By zeoncomp in forum Waterjet General Topics
    Last Post: 03-27-2008, 12:03 AM
  4. Defective SGS products.
    By deleteallusers in forum Material Machining Solutions
    Last Post: 07-03-2007, 03:59 PM
  5. Defective toroidal?
    By JMValios in forum CNC Machine Related Electronics
    Last Post: 12-15-2005, 11:45 PM
