Hello:
I'm searching for stepper standoffs. I need to buy them.
Someone posted a link here for plastic standoffs few weeks back. But forum search returned me zero.
Will be glad if you know the source...who sells them.
Hello:
Would something like this do?
I hope I'm not breaking any rules...
Our Products
I use their products all except for the screws.
Thanks for your reply.
I was actually looking for a simple one. It was look like little pipe.
Someone posted the link sometime back, I just can't find it.
I saw many people used nylon typy stanoffs in their DIY build. I just can't find them anywhere..
McMasters has them, but you have to buy 100....
Lowes has them in the little drawers with the odd hardware parts.
But...by the time you pay for them individually, you may be better
off just buying 100.
You'd have 80+ left to share with your fellow zoners....
John
The only advantage to them is they're all
the same length, making them easy to deal with.
For what it costs to get them, an aluminum tube
cut into sections works as well, looks great, and is
likely easy for you to get.
A little work getting them the exact same length, but It'd
probably save you $20 in the long run.
If you really-really want nylon, I'll send you some if you
want to pay the shipping. I'm not sure where BGD is so
I have no clue what that could cost....
John
Nylon or Phenolic...
Phenolic is a harder material. Nylon works fine.
If you have a lathe and mill available, these are simple to make.
A 1.5" PVC pipe cut to length then slotted, mounted with 4 bolts.
BTW...cheap...and sometimes really nice looking spacers can
be just cut up from larger knitting needles.
All nice and anodized. Some are nice and thick too.
They can often be found in junk stores for next to nothing.
A pipe cutter is helpful for getting aluminum tubes evenly cut sometimes.
John
Very Cool!
