586,089 active members*
3,836 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Stepper only turns in one direction
    Sep 2010
    Please Help
    I am switching over from MicroKinetics software, opti board and opti driver. Am setting up tubocnc, slo-syn ss2000 md4 drivers and same steppers (which worked fine with the opti stuff) –Vexta m06 008 (12v .68a).
    The problem is the motor will only turn in one direction. Using pin 2 step and 3 direction(set high). When I jog the motor, It turns one way no matter with way I jog. If I pull direction pin wire it turns in the other direction. I tried a 10k dropdown res. No change. Hope someone can help me.
    Thanks in advance
    Oct 2005
    2392
    The stepper driver seems to be working ok as when you pull the DIR wire it changes direction.
    It looks like something is pulling that wire to ground, like a short. This could be in the wiring itself or it might be in your opti board at the other end of the wire.
    You can test with a voltmeter that the output of the opti board changes between 5v and 0v (as it should) when jogging each direction. Disconnect the wire from the opti board first, and if the signal out of the opti board connector does not change you know the fault is in the board.
    If the board signal changes ok, but when you reconnect the wire it stops changing, you can assume it's a short in the wiring.
    Either way I would go right over the wiring and connections first with no power connected and inspect it, that is the most likely problem.
  1. Help !! Stepper only turns in one direction?
    By Racelogic in forum Stepper Motors / Drives
    Last Post: 11-21-2010, 12:04 AM
  2. 4th axis turns to many turns
    By cob in forum Mastercam
    Last Post: 02-16-2009, 07:19 PM
  3. Stepper motor only turns one way
    By henryblowery in forum Stepper Motors / Drives
    Last Post: 12-21-2008, 05:01 AM
  4. Stepper turns only one direction
    By jhowelb in forum Stepper Motors / Drives
    Last Post: 10-04-2007, 01:52 AM
  5. Stepper only going in one direction?
    By ScuD in forum Stepper Motors / Drives
    Last Post: 12-09-2005, 12:28 PM
