586,113 active members*
3,573 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Milltronics Centurion 5 450 error Help!
    Nov 2010
    Newbie here, I have a milltronices Centurion 5 retrofit on a Supermax YCM-40.
    I'm trying to get the machine to home but I immediately get a 450 e-stop error. Check each limit switch and they are fine. I've also home (here) then tried to Jog each axis but nothing moved, then excess error! Tried changing the home sequence but nothing. I've gotten the table to move here an there trying different combinations but could never get anything consistent. Just looking for help on what to check next!
    Apr 2003
    637
    It’s normal when you first turn the machine on to get the 450 error. Hitting the green reset button first thing should clear it if the table or head is clear of the overtravel limit switches. Try holding down the green reset button and use the handwheel to move the table clear of the switch. I believe the 450 error could also mean that one of the drives is being over worked by a bad servo drive or bind in the lead screw or linier guides. Also check air supply and lube levels. Do a search of this forum for more info.
  1. Replies: 37
    Last Post: 01-27-2011, 08:10 PM
  2. milltronics partnerIV centurion V
    By bullitt92 in forum Milltronics
    Last Post: 07-06-2010, 10:51 PM
  3. Milltronics 3 axis Centurion 6
    By Chizel in forum GibbsCAM
    Last Post: 05-04-2010, 05:25 PM
  4. Milltronics Centurion Six
    By CUTRITE in forum Milltronics
    Last Post: 10-13-2006, 07:48 PM
