Originally Posted by
photomankc
There are several threads going on Rf-45 conversions and probably you could get some help from the authors. There are several variations though so yours may not be the same as thiers. Also note that generally RF-45s are done using servos and that is going to increase the conversion cost and complexity compared to the smaller stepper conversions. I suppose that one could do big steppers on the RF's but I assume also there is a reason you don't see it being done very often.
I believe the bigger steppers sacrifice a lot of speed... Im sure servos are the way to go... id bet with an RF45 you would look at 4k or so when all is said and done... as for the G0704(or any BF20 clone) it would be more like $1800-$2000....
http://www.g0704.blogspot.com/
