586,036 active members*
4,109 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Please help so I fully understand before jumping in the deep end.
    Oct 2004
    198
    Talking Please help so I fully understand before jumping in the deep end.
    Lets just pretend for a second that I don't fully understand what hardware I need.
    I'm familiar with Camsoft, I set up a 6 axis grinder using Camsoft Professional, using a Galil card and 6 stepping motors (VERY old).
    This is moderately reliable, I think it's the age of the motors and amplifiers.
    Anyhoo's with Mach2/3 I have got a couple of Allen Bradley drives and motors, do I need a card similar to the Galil?
    I'm just unsure how the PC operates the individual drives.
    Also can the Gecko drive or similar be used with any servo motor, I purchased a couple of Allen Bradley Ultra 3000i drives and motors MPL series (27lb/inch), but it would be nicer to go with a cheaper alternative.
    Also one last question, can the motors be different type, e.g servo and steppers on the same system?
    Mach2/3 outputs step and direction signals from the parallel port only. It cannot use motion control cards like the Galil. You're drives must accept step and direction to be able to use them. Gecko's can be usedwith any DC brushed servo motor. I believe it has an 80V limit. Yes, you can mix steppers and servos on one system (using the appropriate drives).
  1. Cad/Cam Example - Help Me Understand
    By bill south in forum Uncategorised CAM Discussion
    Last Post: 06-29-2005, 08:47 PM
  2. .250 Dia x 22.00 deep ??
    By Rekd in forum DNC Problems and Solutions
    Last Post: 02-25-2005, 03:24 PM
  3. How deep with a .375 Carbide cutter.
    By Ken_Shea in forum Uncategorised MetalWorking Machines
    Last Post: 07-27-2004, 11:52 AM
  4. I just dont understand...
    By freezer in forum Uncategorised CAM Discussion
    Last Post: 02-11-2004, 06:55 PM
  5. Drilling deep holes.
    By HSM Joe in forum DNC Problems and Solutions
    Last Post: 05-13-2003, 06:14 PM
