Not sure if this is a fanuc or machine problem but since the machine has a fanuc controller and i have had good luck getting help here in the past i will put it here.
I have a 1991 Kiwa Excel 1310 mustang mill. Every now and then the spidle fails to orient during a tool change(or loses its orientation and goes to the wrong spot). A big pain but not the end of the world. I just reset it and re-orient it.
But today i lost it. I reset it and it might work for one or two changes or 5 or 7. But it always messes up.
I know how to reset it but how does the machine itself know where home is? Is there some kind of switch on the spindle? Could the be something loose inside that needs to be tightened?
Some things i have noticed:
1. More apt to happen if the spindle has been run. I can manually program several changes and it works fine. But once the spindle is turned on its only a matter of time.
2. Normally happens first thing in the morning. Rarely ever after the first half hour of running for the day.
3. when it loses it orientation the new orientation is random
Thanks in advance for any help...
Kirby
