586,471 active members*
3,651 visitors online*
Page 1 of 3 123
Results 1 to 20 of 42
    Sep 2010
    49
    Dust collection :(
    Hi, I built a 65" x 24" CNC, and it runs great! However, I made a serious miscalculation... I grossly underestimated the amount of dust produced
    Even with a shop vac held 1" from the bit the entire time, cutting MDF, my whole work area is covered with fine dust in just a few seconds. While trying to vacuum it up, I sucked 2 keys off of the laptop After digging through my shop vac I found and repaired the keys. Sigh.
    I tried to make my own dust shoe but it did not work... the wet/dry vac was just not strong enough to pick up the dust unless it was 1/2" from the table which is not possible. I also built an exhaust deflector to send the router exhaust to the sides instead of down on the tool. This did not help much.
    I've seen some affordable dust collectors in the range of $150 which are 900 cfm, with a 4" hose. Has anyone used one of these, and is it enough flow to suck the dust from the table a few inches away? Also, I would like to cut fiberglass sheet, and I am concerned that there will be particles smaller than 35 micron and that a dust collector would not catch these but make them airborne instead. I could place the dust collector outside when running, but I don't like the idea of throwing fiberglass dust out into the yard either.
    I really need advice because at the moment my CNC is unusable without some way to contain the dust.
    Thanks!
    Tom
    Mar 2010
    371
    You can find a $139 coupon for the HF 2HP Dust Collector in woodworking magazines. It's one of the HF gems. A lot of folks have this unit. It sucks. You need to upgrade the filter on it. The recommended filter is a Wynn Engineering cartridge .5 micron. There is also a very clever thing called a "Thein Baffle" than can be installed in the DC that does a much better job of separating the chips and larger particles from the air stream. Google it.
    Apr 2003
    312
    Hi Tom,
    I too was TOTALLY unprepared for the amount of MDF flour created while surfacing my table top. Had the same experience with the hand held shopvac wand where it failed miserably at collecting the flying stuff. Since I'm stuck with the shopvac option due to finances... I made an effort to improve the system to work as efficiently as possible.
    First off... it sounds as though you are using the Hitachi M12VC as they have the bottom exhaust vents in the cast router body. I also made a deflector plate immediately following the surfacing fiasco but my end results were a significant improvement. I was able to create a complete null area below the router which help things greatly. I was still hand wanding with the shopvac for dust collection but now the pickup was almost 100%.
    This caused a downstream problem in the shopvac itself. The filter would clog all too quickly and efficiency diminished greatly. Time to make a cyclone! I read a great deal of info about cyclones landing on the dust collection guru's site of Bill Pentz. Bill's Cyclone Dust Collection Research - Home Page Great resource... but geared to industrial or larger collectors... not the shopvac crowd. I then found this... DIY Cyclone Dust Collector - by SimonSKL @ LumberJocks.com ~ woodworking community and it was simple enough but most importantly for me... cheap enough to pursue. I whipped one up and have had terrific success at completely eliminating the clogged filter syndrome.
    I then moved onto the dust shoe. Just finished it actually! It was an evolution rather than a quick birth but the results are impressive. I went through 7 or 8 iterations to arrive at success... but a shopvac system can be made to work and work quite well.
    I realize you are asking about the industrial collectors... but the collector itself will not solve all the dust issues. Dust collection is a system that needs all components to be working together.
    Hope this provides a bit of needed info...
    Steve
    Attached Thumbnails Attached Thumbnails DS_6.jpg   Cyclonedone.jpg   Dustshoe.jpg   DSCF1761.JPG
    aka BOOMER52 >>> http://www.rcgroups.com/forums/member.php?u=159693
    Aug 2008
    409
    Those cheap dust collectors are just that, cheap, I had one in the past and it really didnt move anywhere near 900cfm. You want a 1.75 or 2hp dustcollector. I now have a 1400cfm 2hp collector and it works great, I have hoses run to all my machines and it has no problem keeping up.
    It also has a 0.5micron bag so nothing gets through the bag an into the air.
    If you put your dust collector outside you create a vacuum in your shop, air has to be replaced in the shop from somewhere as its being sucked out. If you have a gas heater or hot water tank you risk sucking the exhaust fumes into the shop and that can be very dangerous.
    If you have no gas appliances in your shop then as long as you have an air intake you should be fine exhausting outside, only issue is keeping the shop warm in the winter, since you will be sucking out all the warm air.
    A good dust shoe is also really important, a good shoe makes a huge difference, if you can build a really good shoe then even your shopvac should be able to keep the dust under control.
    Feb 2009
    38
    Steve,
    That cyclone is NICE!!. You want to share your machining files for it?
    R/
    Mike
    Sep 2010
    49
    Wow thanks so much guys for the help. I looked at the HF dust collectors and at 100 pounds, 33"x24" it's just not going to fit in my tiny work area. I have what is basically a 10' x 20' work shed. Even with a good filter, I'd prefer to vent outside for many reasons..noise being one of them. Moving a 100lb machine outside is not going to work so I am going to need to think of something else.
    Steve, thanks for the cyclone info and especially the dust shoe design. I think I could manage with the cyclon inside and a shop vac outside... which shop vac are you using?
    My concern is with <10 micron dust... I am not sure a shop vac has enough air flow to draw these in even with the dust shoe, but that can be resolved later with a larger vacuum. It's clear a dust shoe and cyclone would be key.
    How much fine dust do you find in the shop vac container after use and how long before you need to clean the filter when cutting MDF?
    Also, have you ever tried redirecting the router exhaust outside the dust shoe? Seems like this would allow more clean air to be sucked in around the skirt?
    Thanks!
    Sep 2010
    49
    Quote Originally Posted by beermkr View Post
    Steve,
    R/
    Mike
    Same question but for the dust shoe
    Oct 2005
    1237
    Don't throw money at the problem. I had the same problem with dust. First i bought a heavy duty shop vac and had the filter clog in five minutes of MDF use. Then I bought an American made all steel cyclone which still let enough dust through the filter was plugged with dust in 15 minutes of use. 6hp Ridgid shop vac- $100. Cyclone with shipping-$105.
    I then bought a HF like the one suggested and a Wynn filter. WOW Worth every penny. The Wynn filter allows twice as much air flow versus the filter bag. If I were to do it over, the cyclone and shop vac wouldn't have ever been bought. I have a router with bottom exhaust and the dust boot blocks this off. A huge difference in the amount of dust released. Also I suffer from asthma. While making the dust boot I turned on the HF vac and it did a great job of sweeping dust out of the air.
    If you neck down the 4" hose to 2-1/4", buy a 4" Y and waste gate. Cracking the waste gate open allows the Vac to spin up and actually pull a better vacuum.
    Feb 2009
    38
    I have a little roll around Delta unit that I bought at Lowes a few years back. It works really well but the bag fills fast and I see the suction reducing as it fills. The cyclone is the way to go I think but you don't really HAVE to have one of these huge vertical units (although they look like they are way easier to empty).
    R/
    Mike
    Oct 2005
    58
    I recently purchased a small cyclone (Onida Dust Deputy) to place in front of my shop vac. It works great, may not have to clean the filter for years! This model sits on a five gallon bucket. I also purchased a metal one for use cleaning up milling machine and lathe chips, I thought the metal chips may be too abrasive for the nylon Dust Deputy, here is a link for two metal cyclones (bought the smaller one).
    eastcaroga items - Get great deals on Crafts, Home Garden items on eBay.com!
    I have not completed my machine but dust and cleanup is a problem with any router, so I bought a new Jet 3HP cyclone (surplus) that I plan to run on just the CNC machine. Hope it works.
    Here are some links on dust collection I have collected for woodworking over the past.
    The Dust Deputy
    ClearVue Cyclones, Dust Collection Cyclone
    The Thien Cyclone Separator Lid w/ the Thien Cyclone Separator Baffle
    Apr 2003
    312
    Steve,
    R/
    Mike
    Hi Mike,
    I tried but ran into the forum file limit issue. I tried EPS but that is an invalid file type and a DXF was too large to post. Same goes for the g-code!
    Steve
    Feb 2009
    38
    Steve,
    I can host it on my hosting plan if you are willing. How big is the file? can you email it to me?
    R/
    Mike
    Mar 2004
    1806
    Quote Originally Posted by Senna View Post
    Hi Mike,
    Steve
    Zip it up, the allocation is much larger.
    Art
    AKA Country Bubba (Older Than Dirt)
    Jan 2008
    241
    Some more questions for yea Steve.
    Just wondering how thick your dust shoe is, and what is the material you've used for the skirt around the shoe? How well is it working?
    The shoe I've made is 1.5" thick, and I think it maybe a little much. I also have no skirt, which I KNOW will be required.
    Insted of using a deflector plate, I made little exhaust ports in the shoe for the router cooling(see pics) (I'll post my DXFs after work)
    I have a Thien Separator lid for a 5 gallon pail. Seems to work really well. But again, haven't run the machine with it yet.
    Chris
    Jan 2008
    241
    Vacuum Shoe
    So here is my shoe... image and DXF file.
    The left and middle get flipped upside down, the right one stays as is. the 3 bolt together.
    The Bosch colt router passes through large hole(left) sets on the base of the middle one,
    the ports allow for router cooling, and the right one allows suction around the bit.
    The base of the router mount is 2.75" square. the hose is a standard 1.25" vacuum line.
    I used a camlock system to mount the shoe... works OK, but sometimes a pain as the cams get stuck.
    Any better mounting options?
    Material: 1/2" MDF
    Attached Files Attached Files
    Apr 2003
    312
    Here's a C/U shot showing the shoe thickness and skirt material...
    Steve
    One key is a skirt to contain the chips, which are flying at a very high velocity coming off the bit. I've seen a steady stream of chips coming off a 10HP router shooting over 5ft.
    The skirt should be at least 1/2" below the end of the tool.
    I prefer to use strip brush material. There's a reason it's used on big industrial routers ($100K plus). It gives the best seal, and conforms to any surface without snagging. I'm using 3" brushes, but will probably use 4" on my next machine.
    And I've said this many times before. If you need to divert the airflow from your router, the problem is poor dust collection, or an inadequate skirt.
    Jan 2008
    241
    I prefer to use strip brush material..
    So where can one fine this material?
    I've bought a cheap paint brush, and was going to use the brissles from it,
    but not sure how to reassemble in an effective manor.
    Got mine at McMaster Carr, but if you're in Canada, they won't ship there. Try here:
    Industrial brush materials manufacturer, custom brush company, rotary bristle, fda approved brushes -
    Sep 2010
    49
    Quote Originally Posted by Mogal View Post
    I tried this, would not recommend it. I cut bristles from a broom, and then drilled several rows of holes around the shoe, and then hot glued in bundles of the bristles. While it did look great,when the bristles touched the table they would be spread apart as they moved, allowing chips to fly out. You would need many rows of closely spaced bristles to make it work... I like the neoprene Steve is using.. seems effective but easier to assemble.
    I am going to try the heavy shower pan liner material from home depot first and if that doesn't work I'll cut up my old wetsuit.
Page 1 of 3 123
  1. Help with dust collection
    By AJ Negvesky in forum Joes CNC Model 2006
    Last Post: 01-31-2017, 09:00 AM
  2. Dust collection : Dust deputy, clearvue min etc. - need some help
    By FoxCNC1 in forum Uncategorised WoodWorking Machines
    Last Post: 03-08-2015, 02:26 PM
  3. Sensing dust level in dust collection bin
    By DonFrambach in forum DIY CNC Router Table Machines
    Last Post: 04-07-2013, 10:26 PM
  4. Dust Collection
    By bkboggy in forum WoodWorking Topics
    Last Post: 02-23-2012, 02:07 PM
  5. Dust Collection
    By signpro in forum Joes CNC Model 2006
    Last Post: 02-14-2012, 02:38 AM
