586,036 active members*
3,493 visitors online*
    Feb 2010
    371
    Exporting 3D in .dxf
    When I try to export a simply 3D model as a .dxf file, it is exported as a flat 2D image of the current view. Is there a way to export a full 3D rendering that you can then use in a CAM program?
    Aug 2008
    386
    .dxf is drawing exchange format. Meaning by definition it is limited to 2D. Is there another format you can export in, like .stl or .stp?
    Joe
    Feb 2010
    371
    Quote Originally Posted by scudzuki View Post
    Joe
    Not true at all. .dxf also includes z axis definitions. I know this for sure because I wrote software that also produces 3D dxf files. Here is an example, (right mouse click and select Save Link As):
    http://www.compufoil.com/3DGullWing.dxf
  1. exporting 3D databases
    By 3D Accuracy in forum Uncategorised CAD Discussion
    Last Post: 07-20-2010, 02:10 AM
  2. Problems with exporting gcode
    By galaxyman7 in forum Mastercam
    Last Post: 04-26-2010, 09:28 PM
  3. Exporting a STL file with Rhinoscript
    By samg in forum Rhino 3D
    Last Post: 10-16-2009, 08:55 PM
  4. Help with exporting to dxf
    By CJdave in forum Solidworks
    Last Post: 04-20-2009, 04:22 PM
  5. Saving / Exporting as .dxf
    By harley4ever in forum Uncategorised CAD Discussion
    Last Post: 10-24-2008, 05:52 AM
