586,069 active members*
3,398 visitors online*
    Nov 2010
    Amada Press Brake
    We just bought a used Amada 12 Foot Press Brake RG170 ProneCam. We started off by bending .080 ALUM and it bent and cycled through fine but when we changed the program to run .050 ALUM it bent the part but wouldnt cycle through to the next bend but if you take the part out and press the pedel it cycles through with no problems. Could anyone help me with this?
    Jul 2007
    10
    Look to see what your max tonnage is set to. It could be off
    Dec 2007
    32
    If you cycle it through without material will it go forward.. How old is the brake
    Dec 2007
    32
    Also make sure you are on foot pedal and not tooling on the key switch..
    MachineMfg Guest
    Re: Amada Press Brake
    You can refer to article titled Troubleshooting 56 Press Brake Bending Problems (With Analysis and Proved Solutions)
  1. Converting Conventional Hydraulic Press Brake to CNC Press Brake with PC
    By aadityadengle in forum Uncategorised MetalWorking Machines
    Last Post: 08-13-2023, 05:23 PM
  2. Amada Press Brake Controller problem
    By jamesbond007 in forum Bending, Forging, Extrusion...
    Last Post: 12-29-2018, 03:38 AM
  3. Amada Pega 344 Punch Press Clutch/Brake Assy Breakdown
    By tony@sm-w in forum Community Club House
    Last Post: 03-15-2012, 12:16 AM
  4. Amada PRESS BRAKE HFT 220-3
    By M7MED in forum Bending, Forging, Extrusion...
    Last Post: 12-30-2011, 03:04 AM
  5. Amada brake press controller nc9 r
    By maplesiport in forum Controller & Computer Solutions
    Last Post: 07-15-2010, 11:32 PM
