Good morning to all. I have a 2003 VF-2SS with a "low Air" alarm that I am unable to track down the problem. Up until now, I have pulled the head cover, located and jumpered the wire to the low air pressure switch (basically bypassing the switch), went into parameter #76 and changed it from 1500 to 9999. I have 100 PSI feeding to the main regulator and the regulator set to 90 PSI. Can anyone tell me if there is another switch in this system to create this alarm? We bought this machine new and have not had any issues until the last few days. Is it possible that the "low air" switch has a normally closed contact and the presence of air opens it or is it a normally open contact and air closes it? I am asking this, because I was getting the alarm every couple of hours, and now it is on constant. ???? I am open to any help out there! Thanks in advance!!!!
