586,121 active members*
3,630 visitors online*
    Cut to the Bone Guest
    Exclamation CAMaster Stinger
    Just wanted to add a Stinger Thread here as we have in other places. This is for customers that visit this fine forum for information and ones that may have intrest in the Stinger. Thanks for looking.
    Ok I will start with the specs of the machine.
    Unless noted all specs will be of the Stinger I Table Top.
    All machines are built by CAMaster in our plant in Calhoun, GA USA
    Cut Area - 25" X 36" X 5"
    Over All Dimensions - 33.5" X 50" X 34"
    Rapid Speeds - X & Y 500 ipm - Z 400 ipm
    Router Weight - 320 lbs
    Shipping Weight - 400 lbs
    Welded Steel Table with Powder Coat Finish
    Hiwin rails and bearings
    Leveling Feet
    MDF Table Top
    Limit Switches on All Axies
    Dust Boot
    E-Stop (On Control Box)
    Bosch 1 HP Router Colt Variable-speed *
    Cut 2D Design Software *
    Windows Based Controller (Includes - PC, Keyboard, Mouse, & Flat Panel Monitor) Pre Loaded with Mach 3 Control Software and Tested*
    * Upgradable Items
    Options are
    2.25 HP Porter Cable Router Upgrade
    Description - Upgrade from the 1 HP Bosch Colt to a 2.25 HP Porter Cable Model 892. This option gives you more power to perform through cuts in substrate.
    1 KW (1.34 HP) HSD/SEV Collet Spindle
    Description - Ultra quite high performance. A spindle upgrade not only takes noise out of the shop it adds value to your router. The Stinger is an industrial quality CNC Router made for the small shop or hobbyist. Add this option to it and you have a small format CNC that is capable of running long shifts without stress to bearing and other components.
    T-Slot Clamping Table
    Description - The T-Slot Clamping Table gives the Stinger the bite to hold down your parts. Four flush mounted aluminum slots give the Stinger a wide range of holding points. Four heavy duty knobbed clamps included.
    Mini Recoil Indexing Lathe
    Description - The Mini Recoil like the larger version on the Cobra Series Routers is a woodworking lathe that has been fitted with a high torque step motor & driver. This motor/driver combination gives the Recoil lathe the ability to break down the segments of a cylinder in to degrees. Unlike traditional lathes that spin without stopping the Recoil can rotate stop and change directions many times in a file. This ability helps 3D software like Aspire and others to control the lathe and make wonderful 3D carved turnings.
    WinCNC Control System Upgrade
    Description - WinCNC control software is an industrial controller that gives the Stinger the ability to truly be an production CNC. CAMaster also offers its Remote Technician Support (RTS) with this option.
    All WinCNC systems are tested by our technicians with your router and control PC.
    V-Carve Pro
    Description - Upgrade from Cut 2D to V-Carve Pro and you will have the ability to use VectorArt 3D files, nesting, V-Carving and more.
    Photo V-Carve Pro
    Description - PhotoVCarve instantly converts photographs and images into high quality toolpaths that can be run on your Sringer. One great example of this would be Lithophanes.
    Aspire
    Description - Upgrade to Aspire to have the ability to perform 3D modeling. Aspire comes with a disk with 7 hours of training and 50 free 3D models from VectorArt 3D.
    Here are some Pics
    Attached Thumbnails Attached Thumbnails PICT0704.jpg   PICT0705.jpg   PICT0434.jpg   PICT0439.jpg
    I got an e-mail on price here is where you can find it.
    The price can be found via an automated quote form on the Stinger web site.
  1. Camaster
    By sngatlanta in forum Camaster
    Last Post: 02-26-2012, 02:44 AM
  2. CAMaster CNC @ IWF 2010
    By Cut to the Bone in forum Camaster
    Last Post: 09-05-2010, 05:57 PM
  3. CAMaster not selling?
    By CDESWORKSHOP in forum Camaster
    Last Post: 03-30-2010, 01:41 AM
  4. How much was your CAMaster setup?
    By bce086 in forum Camaster
    Last Post: 08-04-2009, 10:20 AM
  5. camaster help
    By cruzan in forum Camaster
    Last Post: 10-11-2008, 04:27 PM
