586,106 active members*
2,888 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > How many RS232 ports can we have on the machine
Results 1 to 9 of 9
    Feb 2006
    1792
    I have seen only one serial port on CNC machines.
    Can we have more ports? How many?
    Sinha
    24221
    Usually more than one is possible, depends on what model you have?
    Al.
    Albert E.
    Feb 2006
    1792
    Thanks for reply.
    I am asking with reference to 0i M, model C and D.
    Possibly, one would be connected to a PC, one to a CNC-USB device (for using a pendrive), one being used for some other purpose ...
    Feb 2006
    1792
    I was looking at 0i model D page on Fanuc website.
    It appears that everything is being done through ethernet/PCMCIA.
    There is no mention of RS232. Have they stopped providing serial port?
    2932
    Quote Originally Posted by sinha_nsit View Post
    I just hooked up RS232 communications to an 0iT-D. Same old serial port.
    Feb 2006
    1792
    I am trying to understand it.
    If everything is possible through ethernet, why use RS232 at all which creates communication problems many a time?
    2932
    Everything is NOT possible... you can't drip feed through the embedded ethernet. RS232 is not dead, yet.
    Jun 2008
    1511
    Quote Originally Posted by dcoupar View Post
    LOL. I hope that it takes a long time to die. I have always used RS232 and my attempts at Ethernet have been pretty much nonexistent. To tell you the truth I am a bit timid about trying anything with it. I don’t know if it’s the technology or just bothered that why take something that works and make it more complicated. Now I have to learn something all over again.
    Stevo
    Feb 2006
    1792
    Possibly, someday there would be a few built-in USB ports on the control where we can insert 16GB sticks, completely eliminating memory space problems. Drip feed, if needed, would be directly through the USB. I have heard that even today drip feed through PCMCIA is possible.
    RS232 has to die some day. Who likes a mesh of cables!
  1. 2 Parallel ports
    By DrStein99 in forum LinuxCNC (formerly EMC2)
    Last Post: 08-12-2010, 01:58 PM
  2. Ports and motors ...
    By Jalex in forum Mach Mill
    Last Post: 12-28-2008, 02:37 PM
  3. Hurco KM1 RS232 to USB OR RS232 to PCMCIA solution?
    By modernprecision in forum Bridgeport / Hardinge Mills
    Last Post: 09-11-2008, 07:15 PM
  4. RS232 communications on Mitsubishi FX EDM machine
    By barnescomputer in forum Waterjet General Topics
    Last Post: 02-13-2008, 01:32 AM
  5. SPC Ports What are your Use?
    By SMW Precision in forum Calibration / Measurement
    Last Post: 07-31-2006, 09:46 PM
