Yesterday while jogging the machine I heard a crunching sound. On further inspection, I noticed the spiral ball screw cover was munched up. Can you replace this without breaking the ball screw loose? It seems like you should be able to just coil it around the ball screw. I realize that there is some tension as it seems to be made from spring steel. Any help or insight is greatly appreciated.
Thanks.
