586,740 active members*
2,582 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Finding exact centre of 3mm hole
    Oct 2008
    31
    Hi Can anyone tell me how to find the exact centre of a 3mm countersunk hole?
    Is there a centre finder that can be purchased?
    Ian
    15362
    boxmaker
    There are more than one way to do this, the most common would be to use a test indicator, in the spindle & turn the spindle by hand, untill you have the X- X+ Y- Y+ at 0.0 on the indicator, another way is to use a gauge pin that is tight in the hole & indicate around the pin
    Mactec54
    Jul 2008
    10
    HI there
    are you using a cnc machining centre? fanuc controls or fanuc based controls?
    i have two programmes that will find the centre of a hole using a probe and four points and another programme using 3 points. let me know if you would like it.
  1. Another Aussie Adventure in Optical Edge/Centre Finding
    By Greolt in forum Mach Software (ArtSoft software)
    Last Post: 04-01-2008, 09:48 PM
  2. Finding the centre of an arc
    By Robin Hewitt in forum G-Code Programing
    Last Post: 03-28-2008, 02:02 PM
  3. finding center of a hole
    By BeerFizz in forum Mach Mill
    Last Post: 06-15-2007, 01:17 AM
  4. How to drill a centre hole accurately.
    By Syphonics in forum Mechanical Calculations/Engineering Design
    Last Post: 04-07-2007, 04:31 PM
