Members,
Is it possible to use TTL square wave rotary encoder with 500PPR instead of current interface 11uA with same PPR (both have A,A bar,B,B bar,C,C bar ) into TNC 407.
Members,
The 11µA uses a totally different interface so I cannot see it being possible.
Al.
Albert E.
Thanks AL_THE_MAN
I have another question
On a TNC 407, I have an spare encoder for X-axis siemens ac servo motor. It is not installed to the motor,
Is it possible
- I want to connect it with the control unit.
- By rotating it i want to see change in postition display of X just to confirm that it is in working position.
If it is the same type encoder you should be able to, the controller may give you a following error after so many counts.
Al.
Albert E.
Dear kongzai,
Do you know some links from where to get adapter?
i have no idea of what brand of encoder you are using.
just for your reference, i replaced a Heidenhain linear scale with a set of Fagor's + the adapter, for a much cheaper price.
adapter i used is for 1Vpp to 11uA conversion.
http://www.fagorautomation.com.br/no...TER_SA_P_C.pdf
