586,538 active members*
2,818 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Reset offset after turning machine off?
    Dec 2008
    319
    Do you reset your fixture (g54) every time you turn your machine back on?
    Can I set something up...then turn the machine off and then turn it back on the next day and hit the go button??
    Thank
    Tim
    Jul 2005
    12177
    You do not need to reset offsets after the machine has been turned off. The axis homing sequence (Auto Restart) finds the same location every power up to within better than 0.0002".
    We run machines for weeks without doing anything to offsets.
    But, having said that, I have had funny things happen with rotaries. On two occasions I have had one home to a different position but that is twice in several years of use. Now I do a quick check on my rotary just to be safe.
  1. Series OT Reset and offset parameters
    By tnik in forum Fanuc
    Last Post: 03-11-2010, 06:13 AM
  2. Cinci Acramatic 850SX Tool Offset reset!
    By burnthills in forum Cincinnati CNC
    Last Post: 02-25-2010, 07:44 PM
  3. 0-MD Machine loses absolute coord with reset
    By ILCORKILL in forum Fanuc
    Last Post: 02-25-2009, 06:41 PM
  4. machine reset parameter
    By priyo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-28-2007, 07:45 AM
  5. help with turning tool offset
    By Shizzlemah in forum Centroid CNC Control Products
    Last Post: 09-20-2006, 09:36 PM
