586,068 active members*
3,899 visitors online*
Thread: Lost Steps
Results 1 to 8 of 8
    Apr 2003
    98
    Lost Steps
    I have xylotex 3 axis running at 24 volt and 276 oz/in steppers run by CNCPRO
    I have used it for 2 years with little problems BUT recently started using CAM that out puts programs with thousands of little lines and now I am loosing steps in Z tool gets gradually deeper as it travels across the contour any advice would be greatly appreciated Im at an end
    Learn from the mistakes of others you can't afford to make them all yourself!
    Try lowering the z-axis acceleration.
    Apr 2003
    98
    Yeah I was looking at the formula given in cncpro can anyone elaborate Im not sure what this ^ means here is the formula 1ft/sec^2 Idont recognize this ^ what does it mean ?
    Regards Ray
    power, as in squared ^2 or cubed ^3
    Apr 2003
    98
    OK that helps but how do I apply this formula sorr for the silly questions math is NOT a strong point of mine
    Thanks again
    May 2005
    13
    Ray,
    Acceleration is (Final Velocity - Starting Velocity)/Time
    In this case it would be
    30 IPM - 0 IPM / .25 Seconds (assuming it goes from 0 to 30 in a quarter of a second)
    30 IPM is .5 Inchers Per Second /.25 Seconds
    In the end, that comes to 2 inches / Second^2 (squared)
    Or if we go to google and search for (30 inches / 1 minute) / .25 seconds
    (google is a calculator too ) It says 0.0508 m / S^2 which is 2 inches/S^2
    Hope that helps you or someone else.
    Chris
    BTW, first time post
    Feb 2005
    303
    TazChris:
    Yeah, that helped me! I didn't know google did that!
    Apr 2003
    98
    Update Thanks for the help everyone I installed turbocnc 4 and after a lot of testing of settings I am happy to report that that solved my problem. BTW I tried tcnc 3 some time ago briefly and have to say I love what they have done with it the gui has improved tremendously not to mention it outputs the correct pulses so my router doesnt loose steps is well worth way more than the $60 Thanks for your hard work to all who developed this program
  1. steps Calculator
    By slp_prlzys in forum DIY CNC Router Table Machines
    Last Post: 04-10-2006, 07:24 PM
  2. help with lost steps??
    By chrisw765 in forum Xylotex
    Last Post: 06-16-2005, 09:59 PM
  3. Cause For Losing Steps?
    By FLUTE HEAD in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-14-2005, 01:54 PM
  4. Lost Steps How does it Happen?
    By High Seas in forum CNC Machine Related Electronics
    Last Post: 01-31-2004, 03:57 AM
  5. Changing steps
    By jimglass in forum Gecko Drives
    Last Post: 07-03-2003, 01:20 AM
