586,096 active members*
3,067 visitors online*
    Nov 2010
    almotion usbcnc
    is there a setting required to be able to use the DNC function on a TM-1?
    Nov 2007
    69
    as per page 37 in the manual:
    "DNC is enabled using Parameter 57 bit 18 and Setting 55.
    Turn the parameter bit on (1) and change Setting 55 to On."
  1. Replies: 9
    Last Post: 04-28-2016, 11:42 PM
  2. Vectric-PPs for USBCNC
    By elses in forum Post Processors
    Last Post: 11-04-2009, 11:24 PM
  3. postprocessor for USBCNC
    By Blerbaby in forum EdgeCam
    Last Post: 10-29-2009, 12:25 PM
