Hi, I have been having trouble importing NC code into Mach 3 Mill. I generate the code with MasterCam X2 using the drill toolpath, and I copied the path over again using the transform toolpath. When I verify it in Master Cam, everything looks good (pic attached). Also, I opened it on a free NC viewer, and everything looked good (pic attached). But when I opened it in Mach 3, the viewer showed 2 holes missing (pic attached). When I ran the machine, it doesn't drill those two holes, plus it drills a few of them twice. It is almost like the machine forgot to move before drilling the hole.
Here is the G-code:
O0000
(PROGRAM NAME - TEST2 )
(DATE=DD-MM-YY - 27-11-10 TIME=HH:MM - 12:30 )
N100 G20
N102 G0 G17 G40 G49 G80 G90
( 1/8 CENTERDRILL TOOL - 1 DIA. OFF. - 1 LEN. - 1 DIA. - .125 )
N104 T1 M6
N106 G0 G90 G54 X-.8007 Y.3492 A0. S2139 M3
N108 G43 H1 Z.1
N110 G99 G81 Z-.5 R.1 F6.
N112 X.1552 Y.3316
N114 X-.8042 Y-.1975
N116 X.1834 Y-.2116
N118 G80
N120 X1.1993 Y.3492
N122 G99 G81 Z-.5 R.1 F6.
N124 X2.1552 Y.3316
N126 X1.1958 Y-.1975
N128 X2.1834 Y-.2116
N130 G80
N132 X-.8007 Y1.3492
N134 G99 G81 Z-.5 R.1 F6.
N136 X.1552 Y1.3316
N138 X-.8042 Y.8025
N140 X.1834 Y.7884
N142 G80
N144 X1.1993 Y1.3492
N146 G99 G81 Z-.5 R.1 F6.
N148 X2.1552 Y1.3316
N150 X1.1958 Y.8025
N152 X2.1834 Y.7884
N154 G80
N156 M5
N158 G91 G28 Z0.
N160 G28 X0. Y0. A0.
N162 M30
