Hello everyone, first of all a short introduction-my name is Aleksandar, and I'm here to help a friend of mine with a problem. He's not that good with English, and I know nothing about CNC machining, so I apologise in advance for newbie questions, hopefully you can help us out, he's been working with wood a lot but never with metal.
Anyway, the job at hand is cutting 2mm thick letters out of 80x20 aluminium plate. The router bit diameter shouldn't be over 2mm.
Basically, he'd like to know which router bit you would reccomend, which RPM he should use, which feed and plunge rate?
His CNC router is 1200x800x150. RPM is adjustable from 0-22000rpm.
