586,596 active members*
3,351 visitors online*
    Jul 2005
    Software for an older machine?
    I work for a company that recently puchased an older Camtech. I believe the model number is 5/52. The software that is used to run the machine is called pcu, it is older dos software and is a little unfriendly to use. Is there any options to upgrading to newer software to run this machine. The computer(s) I can run this from are Windows2000 or WindowwsXP.
    24223
    You would probabally need hardware changes as well as software.
    If it has one of the well known motion control cards in a PC slot, then you may be ahead in not having to purchase another. Otherwise there are a few PC based systems outhere to consider. Otherwise unless the company is still around with an upgrade then it will require a bit more than just a simple software installation.
    I just googled them and I see they still operate out of Calgary, so not far from you.
    Al.
    Albert E.
  1. Post Request - older Bostomatic 312
    By aiwnios in forum Post Processors for MC
    Last Post: 04-13-2012, 03:25 PM
  2. Help Older CNC JR controller pinout for Mach III
    By sandtoysrus in forum Servo Motors / Drives
    Last Post: 03-17-2005, 08:14 PM
  3. older fadal control ?
    By tractdesign in forum Fadal
    Last Post: 01-08-2005, 09:26 PM
  4. Older Craftman LAthes?
    By FXRocket in forum Uncategorised MetalWorking Machines
    Last Post: 11-10-2004, 05:01 PM
