586,471 active members*
3,790 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA LB15-II MW LATHE Alarm
    Dec 2010
    Question OKUMA LB15-II MW LATHE Alarm
    1008-13 Alarm A SVP DIFF over Z Axis alarm
    Anyone see this before?
    Mar 2009
    1982
    what indication on drive unit itself shows?
    when this alarms occurs? Is it resetable?
    Apr 2009
    1262
    When the DIFFerence between the actual position on Z and the commanded position on Z become too great, this alarm is generated. It usually occurs when there is a mechanical bind or collision on Z.
    Check for chips in the ball screw/slide area, or some other mechanical binding with covers, slides, ball screw etc. if no oops has occurred.
    It may be helpful to watch the load meter on Z (actual position - page down a few times) as you move with the pulse wheel to watch for load increasing. You can also see RAPA, RCON and DIFF on another page to watch DIFF increasing if there's a bind.
    Best regards,
    Dec 2010
    For whatever reason, the machine just started running, and has been running for two shifts. Not sure what the problem was. Thank you for your replies!
    Mar 2009
    1982
    check if Z axis is lubricated properly.
    If it is vertical m/c check condition of balancing hydraulic cylinder also (maybe there is no such a cylinder on your machine).
  1. Replies: 5
    Last Post: 01-09-2018, 12:07 AM
  2. okuma LB15
    By NJC in forum Okuma
    Last Post: 04-11-2013, 05:40 AM
  3. I need IGF manual or pdf for okuma LB15
    By cncldwms in forum Okuma
    Last Post: 10-24-2012, 02:20 PM
  4. Okuma lb15
    By firepoker1965 in forum Okuma
    Last Post: 09-23-2009, 02:01 PM
  5. OKUMA LB15 "ALARM 206 A Shear Pin 4"
    By RISNA in forum Okuma
    Last Post: 06-16-2008, 04:35 AM
