586,042 active members*
3,750 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Converting DWG file to a PDF
Results 1 to 9 of 9
    Jul 2010
    369
    If anyone out there knows how to convert a .dwg file to a .pdf file,
    can you please help?
    Thanks in advance for all info.
    Mar 2004
    761
    Here is a free PDF printer that should work for you.
    CutePDF - Create PDF for free, Free PDF Utilities, Edit PDF easily;.
    Quote Originally Posted by Perfect Circle View Post
    Wayne Hill
    Jul 2010
    369
    Much thanks Wayne!
    I use Primo PDF.
    24221
    PDF995 sets up as a printer also.
    Also free.
    Al.
    Albert E.
    Aug 2010
    90
    convert to pdf
    if needs be, try FREE PDF Printer - always works for me-kman:rainfro::rainfro::rainfro:
    Nov 2010
    I use CutePDF, it is free and I use it to convert .DWG,.DXF to .PDF
    Cute PDF
    I Also use CutePDF. Works great!
    Jan 2011
    30
    Plot to file from Autocad
    Not sure which version the change was made, but you can "plot" to a pdf file from within Autocad and avoid an addon. Past Acad 2009
  1. Replies: 8
    Last Post: 05-04-2015, 12:49 PM
  2. Converting a pdf file to UG part file
    By gaoxingdcf in forum UG NX
    Last Post: 05-20-2010, 01:47 AM
  3. Help with converting file
    By slink74659 in forum Uncategorised CAD Discussion
    Last Post: 10-18-2009, 12:38 AM
  4. converting a mastercam 9 file into a Solidworks file
    By Michael82 in forum Solidworks
    Last Post: 04-17-2009, 07:14 PM
  5. Converting a File
    By Tazzer in forum ArtCam Pro
    Last Post: 10-30-2005, 11:52 PM
