586,096 active members*
3,725 visitors online*
    Dec 2007
    17
    DeskCNC importing DXF-wrong toolpaths
    Hello,
    I have a DXF file that I'm trying to cut on a CNC XYZ router with DeskCNC.
    When I load the file, then select all, then generate toolpaths, I select a cutting bit, then generate the G-code. The toolpaths generated are incorrect. How can I fix this? Is this a problem with my CAD program (I'm using Google SketchUp Pro) or is it have to do with the way I'm generating the toolpaths in DeskCNC?
    Attached Files Attached Files
    Jul 2010
    369
    I can't get your file to open up at all in Autocad....
    Dec 2004
    783
    Deskcnc wont do 3D .DXF's, and doesnt like anything in .DXF's but lines, arcs and some polylines, Any dimensions or text has to be exploded into lines or arcs for Deskcnc to correctly read it.
    Try this file, just a trace over yours done in Turbocad<~~Which I highly recommend, any version is good, some can be bought for as little as $10, and I have never had a problem with DeskCNC using .Dxf's from Turbocad.
    Dylan
  1. Can anyone help me with toolpaths for this???
    By cloverfield333 in forum Mastercam
    Last Post: 12-21-2009, 04:21 PM
  2. new 3d toolpaths
    By camtd in forum GibbsCAM
    Last Post: 01-01-2009, 10:06 PM
  3. Need help with toolpaths.
    By vigilante212 in forum Mastercam
    Last Post: 11-14-2007, 10:51 PM
  4. OMG all the toolpaths!!!
    By dbtoutfit in forum Uncategorised CAM Discussion
    Last Post: 06-18-2006, 06:42 PM
  5. DeskCNC and Toolpaths
    By NeoMoses in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-23-2003, 03:53 PM
