586,121 active members*
3,031 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Floppy to USB Converter install
Results 1 to 9 of 9
    Apr 2003
    1873
    Received the converter today, it took only 4 days from the time of shipping to get here in Ohio from India.
    It was packed well with no visible damage.
    Purchased from
    Kwality Enterprises
    80, Queen's Road
    Near Hotel Suncity Towers,
    Amritsar (Punjab,India).143001
    Ph: 0183-2224554, Fax:0183-5005595
    (m): +919780485865
    email
    Vishal Chohan
    [email protected]
    Install was pretty straight forward, the unit replaces the 3.5" drive.
    There was a little pin confusion shown in the photo.
    Vishal's solution was to just press the ribbon cable a bit harder and it will unblock that pin, which it did.
    Formatting of the flash drive was pretty straight forward as well, the usual issues of not really knowing what was expected but all went well on this and the install after just a couple inquireing email, all answered promptly.
    Each flash drive is formatted into the equivalent of 100 3.5" Floppies.
    These 100 (0-99) blocks of floppy equivalents can be accessed from the converter at the control.
    To save files to these block from the PC requires a separate program that is included with the converter purchase, this software also formats the Flash drive.
    True, an extra step is required to save data on each individual block from your PC, but it is quick and uncomplicated.
    You have the equivalent of 100 floppies on the flash drive (a 4gb is recommended) so you must remember on what block your CNC Post is on.
    So now, hopefully, all those many trips back to the PC to reload the post onto yet another floppy will be a thing of the past.
    It worked well on first use, time will tell on the full scope of it's use and reliability.
    Now, what to do with 4 cases of floppies
    Ken
    Apr 2010
    260
    So are you saying that if you had a post that we equivalent to 100 floppy disks, you have to brake up that program into 100 pieces in order to save it to the flash drive?
    www.machmachine.com
    Apr 2003
    1873
    Quote Originally Posted by dingo0722 View Post
    Yes, the flash drive is now formatted to 100 blocks, each block like a separate floppy.
    Many controls that used the old 3.5" have 1mb, and much less on even older machines, my Haas TM-1 has 1mb so it is a good match for these machines.
    This was designed as an alternative to the generally unreliable floppies and so far seems to do a great job
    If one was able to drip feed from the USB, now that would sure be nice.
    Apr 2010
    260
    So my machine has 4MB memory, could I set this up into only 25 blocks?
    www.machmachine.com
    Apr 2003
    1873
    Doesn't seem likely, as the control still is expecting to be reading a 1.44mb floppy.
    If you have post on say block 00 and 99 then you would have to be sure the converter is showing which one you want to read from, or save two. That is what the two numbers indicate, you go up or down in blocks by pushing one of two buttons.
    EDIT:
    This is not a converter short coming, it is the way the control or PC is requiring.
    Sep 2004
    209
    If you have a program that is larger than 1 floppy, you could connect the RS232 port to a PC. The cable is cheap, especially if you make your own, and DNC software is free for download on the web.
    Apr 2010
    260
    we use the RS232 now. Often as a buffered input. I was hoping threre was a way to elimiate that by using a usb thumb drive, but it appears this is not the case
    www.machmachine.com
    Oct 2006
    586
    I would like to see a simple floppy converted into a usb reader should be simple and cost effective.... but I have not found anything of the sort
    individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
    Aug 2010
    579
    Ken Foulks
  1. 31/2 floppy converter for many cnc machines
    By plrelectronic in forum News Announcements
    Last Post: 10-28-2010, 06:00 PM
  2. 3.5 floppy
    By Delvis in forum Fadal
    Last Post: 03-27-2010, 06:02 AM
  3. floppy to usb, crt, pendant
    By Cartel, LLC in forum Haas Mills
    Last Post: 03-19-2010, 09:12 AM
  4. DNC from floppy drive
    By jwknow in forum Haas Mills
    Last Post: 03-11-2010, 03:39 PM
  5. Floppy Drive
    By advt001 in forum Cincinnati CNC
    Last Post: 10-12-2008, 03:35 AM
