586,072 active members*
4,369 visitors online*
Results 1 to 8 of 8
    Sep 2010
    Is this Code Correct?
    Hello
    I want to write Gcode for a part of Two inside Circle(Arcs) with same center and diffrent radius. but I wrote it simple and I do not know where is problem?
    my code is;
    G00 X0 Y4
    G02 X4 Y0 I4 J4 R4
    G00 X2 Y4
    G02 X4 Y2 I4 J4 R2
    and if I want to write a Gcode for full circle how do I write ?I want to use just G00 and G02 with 2 lines.I have Gcode for circle but I do not want to use it.
    Feb 2006
    1792
    Plot it. You will yourself find out the error.
    Use either IJ or R, not both. If you specofy both, IJ is ignored and R is used (on Fanuc).
    Nov 2008
    12
    Hello
    I think you can try by entering -sign in R parameter value.
    Sep 2010
    Quote Originally Posted by HAR THA View Post
    Hello
    Thank you
    you mean the code of full circle is:
    G00 X1 Y4
    G02 X1 Y4 R5
    because the start point and end point Must be same.
    Is that right?
    Sep 2010
    1230
    Quote Originally Posted by Farzaneh_2010 View Post
    Thank you
    G00 X1 Y4
    G02 X1 Y4 R5
    Is that right?
    R will not work with a complete circle with a Fanuc control. R with a minus sign is programmed when the arc angle is greater than 180deg. However, when the start point of the circular move is the same as the end point (a complete circle), the arc angle is computed as zero deg and the machine will not move if programmed with an R value. I and or J must be used with a complete circle.
    Regards,
    Bill
    2932
    Hello
    my code is;
    G00 X0 Y4
    G02 X4 Y0 I4 J4 R4
    G00 X2 Y4
    G02 X4 Y2 I4 J4 R2
    What control is this for? It won't work for a Fanuc, Yasnac, Haas, or similar controls. These controls use I and J to specify the center location incrementally from the start point of the arc. Some controls use I and J as absolute center coordinates, in which case this code might be correct.
    Apr 2010
    294
    If you remove the R codes and end up with just this:
    G00 X0 Y4
    G02 X4 Y0 I4 J4
    G00 X2 Y4
    G02 X4 Y2 I4 J4
    it seems to work, if I and J are absolute values.
    For I and J as incremental values, try this:
    G00 X0 Y4
    G02 X4 Y0 I4 J0
    G00 X2 Y4
    G02 X4 Y2 I2 J0
    For complete circles, with absoloute I and J try this:
    G00 X0 Y4
    G02 X0 Y4 I4 J4
    G00 X2 Y4
    G02 X2 Y4 I4 J4
    Or complete circles with incremental IJ:
    G00 X0 Y4
    G02 X0 Y4 I4 J0
    G00 X2 Y4
    G02 X2 Y4 I2 J0
    Feb 2006
    1792
    Absolute or incremental IJK are parameter dependent. Usually, these are incremental distances from the start point.
  1. Correct Pay??
    By j-radkemachine in forum Employment Opportunity
    Last Post: 11-12-2012, 02:37 PM
  2. Correct voltage and amp. on m-code relay
    By kbspeed in forum Haas Mills
    Last Post: 10-12-2010, 09:14 PM
  3. What's the correct post processor code for EMC2?
    By OneAndy in forum Uncategorised CAM Discussion
    Last Post: 10-19-2008, 03:05 AM
  4. Please correct me if im wrong.
    By Craigpat in forum Gecko Drives
    Last Post: 09-24-2007, 04:48 PM
  5. 086 Alarm - How do I correct?
    By maxvic in forum Fanuc
    Last Post: 04-14-2007, 08:06 PM
