Larry, I would not completely agree with that in the general sense, I think it is a good idea to monitor the health of any controller and ideally place the result in the E-stop string somewhere as is done in most industrial systems, In the Galil and Acroloop cards I use, both have means of monitoring the internal watchdog timer and use this to disable critical power if the system is not running.
I would have thought that this would be especially important in systems such as Mach where the loop is closed externally?
Maybe this is a glitch in the Mach S/W if it does not maintain a specific output when it should?
Maybe using the charge pump to monitor the PC would have been a better choice, if this was not already done?
Al.
Albert E.
